Old 06-10-2009, 09:36 AM   #19
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
WINDO-WELD AT THE TOP?
I wouldn't expect that to hold against a stiff spring that's being bent in it's perch. Maybe if you happened to have a completely loose spring it would keep things aligned as the car came down?
If you want simple... old swing-axle cars (like my Spitfire, old VW bugs and Corvairs) sometimes used "droop limiters". They used them for a different reason, on those cars, when the axle droops, camber goes positive, and if you come down on it quickly while the camber is way positive... it's not pretty.
But, all you need is a strap or cable or chain or something to keep the axle assembly from falling low enough to unseat the spring. Sort of the same thing we're already doing with the shock. That's exactly what the shock does at full extension, it limits the droop of the axle. Adding a droop limiter takes that load off of the shock, which is probably a good thing.
June 13th Shannonville Full Track lapping event! Touge.ca Canada 0 06-04-2009 06:48 AM
June 21st Cayuga TMP track lapping event, 2009-6th Touge.ca Touge.ca Canada 0 06-04-2009 06:47 AM
New photos of my Yari with my new suspension - coilovers (track) Trish Photo-Video-Media Gallery 35 05-25-2009 12:56 AM
2009 Track lapping events, Touge Motorsports, www.Touge.ca. Touge.ca Canada 3 04-26-2009 04:49 AM
Yes, I can finally post here! (Confessions of a track newbie) cleong Tracking, Racing, Auto-X Forum 12 10-20-2008 11:43 AM
