#1 | ||
Apexing Egg!!
so now, we can use a shorter spring for a higher rate, as long as we use a strap to shorten the droop! 400 lb rear springs, here we come?
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
#2 | |
Break'em off some.
If you can find a 400# spring of the right diameter and length, you could do it now with no perches. You will definately need straps for those HTS shocks. Assuming the spring can sit on the stock perches,you can roughly figure out the length needed measuring the length of your current spring with the car on the ground. Then take the weight of the car, and the weight distribution, and figure out roughly how much weight is on the rear tires. Remember you have 2 rear springs so you want to devide this weight by 2. You know it takes 400lbs to compress the spring 1 inch. Do the math and you will have your approximate free length. It should only be around an inch more than the measurment of the compressed spring. There is not a lot of weight back there. Strap placement will be tricky, so you will need to figure that out. You would set the droop so that the spring could never fall out if the rear suspension were to become unloaded or if an inside rear tire left the ground in a corner. That type of full articulation is actually more droop than if both rear wheels were off the ground. If you set the droop such that the spring is unloaded, but still touching the perches, you should be fine. You have the "dome" of the perches to hold the spring in and give you a little extra buffer in a 3 wheel situation. Unfortunately with stiff spring like that you wont be left with much rear droop. This is fine for the racetrack, but may be a little harsh on the street. Last edited by largeorangefont; 06-10-2009 at 10:36 AM. |
say what, 40% of 2300lbs? 920lbs total, split that and you have 460 lbs each spring.
so you'd get 1.15" of compression at rest..
Break'em off some.
if i cross from a parking lot to the street at a diagonal angle, i'm two-wheeling every time. i've gotten used to it, but have had strangers at the gas station comment on it lol
#6 | |
Break'em off some.
Lets say you hit a pothole with yout right rear. With no droop the entire weight on that wheel falls into the pothole, you feel the car drop into the hole. Upon exit of the pothole, that wheel would reload the left front wheel, and you would feel the wheel and car lifting up and out of the hole. It would feel very jaring. |
#7 | |
#8 | |
What?
For the back of the Yaris, if you did something like stacking a 6" 400# spring with a 2" 200# spring, the low rate spring would be mostly compressed under the weight of the car and as soon as you entered a turn, the outised spring would coil-bind and give you the 400# rate that you want for cornering. The inside spring would extend, giving you the full effect of the two springs, which nets a nice, soft 133# rate that would be in effect when that wheel came down to smooth things out. Ground-Control sells the springs you'd need to do that if you wanted to go with 2.5" ID springs. |
ground control utilizes eibach :) so you may be able to source them cheaper thru someone else?
#10 | |
Break'em off some.
I used to know a place that sold lightly used springs from race cars, eibach and hypercoils for cheap. I'll see if i can dig it up. They wanted like $30 per pair. |
#11 | |
Break'em off some.
That would absolutely solve the problem if there was room to make it to work. |
#12 | |
What?
I just wanted to throw that out there as an example of what can be done if a person were so motivated. |
What?
If? This is a situation that anyone who's going this far with their suspension needs to PLAN on. The young guys working course at the BMW club autox I went to last weekend were calling me "tripod" at the end of the day!
The inside rear wheel will be in the air more than it's on the ground unless you're going straight. |
#14 | |
Break'em off some.
#16 | |
What?
You're not really losing any grip, though. The overall cornering potential of the car goes up. You're taking grip away from the rear where it wasn't needed and transferring it to the front where it was. |
#17 | |
Break'em off some.
| June 13th Shannonville Full Track lapping event! | Touge.ca | Canada | 0 | 06-04-2009 06:48 AM |
| June 21st Cayuga TMP track lapping event, 2009-6th Touge.ca | Touge.ca | Canada | 0 | 06-04-2009 06:47 AM |
| New photos of my Yari with my new suspension - coilovers (track) | Trish | Photo-Video-Media Gallery | 35 | 05-25-2009 12:56 AM |
| 2009 Track lapping events, Touge Motorsports, www.Touge.ca. | Touge.ca | Canada | 3 | 04-26-2009 04:49 AM |
| Yes, I can finally post here! (Confessions of a track newbie) | cleong | Tracking, Racing, Auto-X Forum | 12 | 10-20-2008 11:43 AM |
