Old 06-12-2009, 11:32 PM   #1
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Cut the springs, buy some limiting straps, install them and enjoy.
Old 06-13-2009, 07:50 AM   #2
kngrsll
Apexing Egg!!
kngrsll's Avatar
good thread, good to know about the springs, and MMMMMMMMMMMMMMMM at those wheels! can't wait to see your +15mm rear fitment! did you install your hub spacers already?
I got them yesterday as well, i was going to save them for another thread. I have not put them in yet though!
Originally Posted by Loren View Post
Simple math here. One rear corner = 2300 x .5 x 40% or about 460 pounds.
Your 123# spring is compressing approximately 460/123 or 3.75" to an installed length of about 8.25". (this is disregarding motion ratio just for simplicity)
Your 275# spring is only compressing 460/275 or about 1.75" to an installed length of 10.25"... a full 2" taller than stock.
Your actual results were about 3/4" more than that, but looking at the side-by-side photo, the old springs were maybe half an inch shorter than the new ones. That's part of it. The rest probably comes down to not considering the motion ratio, etc.
My point is that if you'd done a little math, you should have EXPECTED your new 275# spring to raise the car by at least 2" without question. Can you get 10" springs or 9" springs?
Very cool that "standard" race springs fit so well. How 'bout some photos of how they fit in the perches? This is neat stuff!
yea, i agree, i should have done that. Either way, the shortest they make is 11", so it may not have been adequate enough.
I think this is exactly what i am going to do!
then i will get pics of them in the bottom perch. They fit so good!
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
Track Suspension id3379 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 85 06-11-2009 05:59 PM
Rear spring swap info The Spectacle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 02-22-2009 09:37 PM
ideal spring rates for coil-overs on Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 30 01-27-2009 04:24 PM
