Verbieten Sie
Help! Brake light issues!
Okay, so when I changed my oil I noticed that my brake light was out. I replaced the bulb, and the tail light is working.. but brake light still is doing nothing. This is the passenger side on an 07 liftback.
Thoughts? Think maybe I have a short or something? |
![]() ![]() ![]() Drives: '08 5-door Join Date: Apr 2009
Not a short unless it's blowing fuses. More likely to be a loose ground wire somewhere.
#3 | |
Verbieten Sie
Learn to Relax
The grounding is usually close by. Look for a wire out of the bulb socket that attaches to the chassis.
ekodrvr
Drives: 2002 white subaru impreza wrx Join Date: Feb 2009
just as a side note, i would be pretty sure that the ground is fine, as the tail light side is working... my suggestion is to check to see if there is a short in the wire from the bulb to the last splice in the brake light circuit, or to make absolutely sure on the light bulb being correct...
if you want to see my plans for this car, check out here... http://www.cardomain.com/ride/3154316 i like this smiley...
![]() ![]() ![]() ![]() Drives: '07 Yaris turbo, '11 Juke Join Date: Mar 2007
Check the brake fuse located under the dash. Do you have and auto or manual?
http://www.cardomain.com/ride/3875996 |
ekodrvr
cannot be fuse if it is only one bulb... only circuit that has individual fuses like you are thinking is the headlights so that you can limp home with one light to see by at night...
the brake lights have their own fuse and another one for the illumination. My brake lights didn't work but everything else did. I replaced the brake fuse and it fixed the problem. I also could not shift out of park until the fuse was replaced. I missed the part about just the passenger side
#9 | |
Is your bulb dual filament? |
ekodrvr
update?
Great safety feature. All too many morons on the roads with no brake lights. I guess they don't have $5 and 5 minutes install time to save themselves from a wipelash.
#12 | |
Rides canyon walls
Drives: 1988 RX7 FC 10th AE Join Date: Jun 2007
anyways...yeah, so check your fuses man @_@
![]() OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header |
Verbieten Sie
Haha, well when I move around the wire connected to the tail light bulb it turns the light off and on. So I think it's something to do with the wires? The brake light and tail light use the same bulb, and the tail light works, but not the brake light. The other two brake lights work.
ekodrvr
okay well, you found where the system is shorted, and that would be a relatively simply fix... however, take it to a shop of some sort because said shop will warranty their work, FTW
what number is the brake light fuse i just put in rs lights and all globes work but the brake lights dont
thanks again mate
#18 | |
![]() Drives: yaris Join Date: Feb 2009
fuses
where is the illumination fuse?!?!?!?! |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! | mizhgolightly | DIY / Maintenance / Service | 45 | 05-03-2022 03:59 PM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 05:43 PM |
| Help Needed - Brake Light Question | *MAD DOG* | Cosmetic Modifications (Exterior/Interior) | 21 | 02-08-2009 06:32 AM |
| Removing third brake light | lightyearsgirl | DIY / Maintenance / Service | 8 | 08-06-2006 12:26 PM |
