Old 06-13-2009, 06:54 PM   #1
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Now, the question is... what spring rate did you end up with?
We can do some math and get close. Give me the diameter of the wire, the number of active coils "before" and the number of active coils "after" and I'll crunch it for you.
This is awesome stuff. After today's autocross, I think a tad more rear rate (even more than the 400# I already have) would be good. Will make it kinda clunky on the street, which it already is. But, I'm still having to jack the rear shock adjustment to almost full stiff to get the front to hook up like I want it to. Need more rear rate!
Old 06-13-2009, 07:07 PM   #2
kngrsll
Apexing Egg!!
kngrsll's Avatar
what rates are you running up front again?
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
Track Suspension id3379 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 85 06-11-2009 05:59 PM
Rear spring swap info The Spectacle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 02-22-2009 09:37 PM
ideal spring rates for coil-overs on Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 30 01-27-2009 04:24 PM
