Old 06-23-2009, 07:15 AM   #1
CB900F2
Drives: 08 Sedan
Great looking lines..
How much firmer do you find the peddle? How much did the kit cost?
Thanks
Old 06-23-2009, 08:01 AM   #2
Brian
Brian's Avatar
Do your rear lines go all the way to the rear brakes? Look kind of short to me.
Old 06-23-2009, 01:06 PM   #3
AlainMikli
AlainMikli's Avatar
Thanks
Um...before I step around 70% of the peddle to stop in some normal speed(local stop sign & traffic light) and takes a long time to stop.
now, I only step 40% to stop my car effectively.
In some highway at 60-70mph, I have to down shift to 3rd gear in order to stop for a traffic light, now I can stop at 4th even 5th gear in the same length & time.
Plus, 2 of my usual passenger say the same thing, before they felt I stop the car very very soft & take a long time to stop it, however they can tell when I step on the peddle right now
$120 for the goodridge ss brake line
Originally Posted by vten View Post
nice work Him ....
did you have to bleed the lines ? how to do it ?? my brakes setup are still waiting to be install ....and so does my exhaust ....
thanks Tan
what are you going to have on your brake setup?
To do: Supercharger…
Old 06-23-2009, 01:22 PM   #4
staticorex
staticorex's Avatar
Drives: Sc'd Yaris Sedan.
Nice. But I'd like to see pics with the rotors on.
Old 06-23-2009, 01:28 PM   #5
AlainMikli
AlainMikli's Avatar
Sure, I'll post some after I wash my car today
Old 06-23-2009, 01:30 PM   #6
staticorex
staticorex's Avatar
Woot. :p
Old 06-23-2009, 01:55 PM   #7
Brian
Brian's Avatar
I'm still wondering why the goodridge lines only go half way instead of all the way to
the drum and if it makes any difference.
Old 06-23-2009, 01:58 PM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
nope.
teflon is gonna expand more than steel brake tubing. the shorter the teflon the better.
Old 06-23-2009, 06:45 PM   #9
AlainMikli
AlainMikli's Avatar
If you see the metal line after the rear SS line, you'll know why they didn't go all the way. The whole SS line idea is to replace the rubber brake line right. Since we are having drums at the back and will have metal line goes to the wheel cylinder, but not the line(rubber) in front of it, so by replacing the line in front of it will have better fluid pressure to it because it won't expand as much as the factory rubber one when they heat up, it will also take less time for the fluid that goes to the cylinder. It is all about fluid travel/pressure. Correct me somebody if I'm wrong or my English is wrong, haha.
Old 06-24-2009, 03:32 AM   #10
AlainMikli
AlainMikli's Avatar
Woot. :p
forgot to upload the pic
Old 06-24-2009, 03:44 AM   #11
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Hmmmm , me likey a lot
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
OEM Yaris brake pad kit PICS auxmike DIY / Maintenance / Service 17 11-24-2009 11:42 AM
Will XA XB's brake line fit our Yaris?? AlainMikli Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-04-2009 01:22 AM
ALL-NEW PRODUCT LINE: DISC ITALIA ROTORS and PADS kargoboy YarisUniverse 11 01-20-2009 04:43 PM
