Old 06-23-2009, 01:55 PM   #1
Brian
Brian's Avatar
I'm still wondering why the goodridge lines only go half way instead of all the way to
the drum and if it makes any difference.
Old 06-23-2009, 01:58 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
nope.
teflon is gonna expand more than steel brake tubing. the shorter the teflon the better.
Old 06-23-2009, 06:45 PM   #3
AlainMikli
AlainMikli's Avatar
If you see the metal line after the rear SS line, you'll know why they didn't go all the way. The whole SS line idea is to replace the rubber brake line right. Since we are having drums at the back and will have metal line goes to the wheel cylinder, but not the line(rubber) in front of it, so by replacing the line in front of it will have better fluid pressure to it because it won't expand as much as the factory rubber one when they heat up, it will also take less time for the fluid that goes to the cylinder. It is all about fluid travel/pressure. Correct me somebody if I'm wrong or my English is wrong, haha.
To do: Supercharger…
Old 06-23-2009, 09:38 PM   #4
Brian
Brian's Avatar
Makes sense. I have rear discs so mine go all the way to the rear calipers. I did have
to order the lines designed for the Vios with rear discs.
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
OEM Yaris brake pad kit PICS auxmike DIY / Maintenance / Service 17 11-24-2009 11:42 AM
Will XA XB's brake line fit our Yaris?? AlainMikli Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-04-2009 01:22 AM
ALL-NEW PRODUCT LINE: DISC ITALIA ROTORS and PADS kargoboy YarisUniverse 11 01-20-2009 04:43 PM
