![]() ![]() ![]() Drives: ings 09 Yaris 3 Door LiftBack Join Date: Mar 2009
SS Brake Line + Brake Pad + Rotor Installed~
Installed Today:
Goodridge Stainless Steal Brake Lines (Front & Rear) CarboTech brake pads + Drilled+Slotted Rotors (fron Garm )Now, I really feel I'm stopping when I step the brake pedal
REAL JDM ings+1 Full Body Kit…REAL JDM C-One Spoiler…Retrofit Projector Headlight…Kiddo 6-pots BBK…CE 28N J-Time Attack…Bride Ergo II Racing Seat…Personal Steering Wheel…Work Bell Quick Release…Dealer Option Sun Roof…JDM RS LED Side Mirror…JDM RS Taillight…C-One Oil Cap…C-One Radiator Cap…TRD Iridium Racing Spark Plug…Tom's Fuel Map Controller…Blitz throttle controller…GReddy Informeter Touch…MR Suspension…TRD Rear Sway Bar…MR C-Pillar Bar…GTspec Front Strut Bar & Rear Strut Bar…AFE Intake…WR Header…Nitto Mid-Pipe…Greddy Ti-C axleback…Goodridge SS Brake Line… To do: Supercharger… |
![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
Great looking lines..
How much firmer do you find the peddle? How much did the kit cost? Thanks |
Do your rear lines go all the way to the rear brakes? Look kind of short to me.
why is the tab on your camber bolt pointing down instead of in?
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
nice work Him ....
did you have to bleed the lines ? how to do it ?? my brakes setup are still waiting to be install ....and so does my exhaust .... |
What?
Drives: 2007 Yaris LB Join Date: Nov 2008
Of course you have to bleed the lines!
Couple thoughts on this brake setup. First, as the OP said, he FEELS like he's stopping when he steps on the brakes. Now, in reality, that's all it is. "Feel". The factory brakes might not give you the ultimate in "feel", but they WILL stop the car as quickly as the TIRES are capable of. Any other brake setup you put on the car isn't going to stop the car any faster with the same tires. I'm not saying the feel isn't good or important, though. The SS lines reduce the amount of give in the hydraulic system, which can directly be felt in the brake pedal as less movement. The brakes will actuate quicker and respond to your inputs under threshold braking a little better. (IF you have the skills to take advantage of it) And the Carbotech pads will likely grab a little better when cold and a LOT better when hot, which is most of the difference that you can feel. The result of that is more braking with less pedal effort. Not "more braking", really... just "less effort". The main reason to upgrade brakes from a performance aspect is so they'll handle more heat. This is the biggest thing that the Carbotech pads will do for you. In a track environment where you're making repeated decelerations from high speed, the stock pads will fade pretty quickly. A good pad like the Carbotech will take a lot more heat before it begins to fade. Good stuff... if you go to the track. BUT... if you go to the track, please don't use those drilled rotors! They're fine for the street, but I can't tell you how many drilled rotors I've seen at race tracks with CRACKS in them. In street driving, we don't normally get our brakes super-hot, and it's not a problem. But, in racing, we DO get the brakes really hot, and those holes in the rotor create weak areas that are an invitation for a crack to begin. Bottom line: Great setup for street, looks good. Will "feel" better, and will offer a little more resistance to occasional mild heat fade. But, for the track... leave the blingy rotors and get some solid rotors. They'll dissipate heat better and they won't be prone to cracking. |
Sure I have bleed the lines!
Thanks Loren, very detail explanation Last edited by AlainMikli; 06-23-2009 at 01:16 PM. |
#8 | ||
now, I only step 40% to stop my car effectively. In some highway at 60-70mph, I have to down shift to 3rd gear in order to stop for a traffic light, now I can stop at 4th even 5th gear in the same length & time. Plus, 2 of my usual passenger say the same thing, before they felt I stop the car very very soft & take a long time to stop it, however they can tell when I step on the peddle right now ![]() $120 for the goodridge ss brake line ![]() Quote:
![]() what are you going to have on your brake setup?
![]() ![]() ![]() ![]() Drives: Sc'd Yaris Sedan. Join Date: May 2007
Nice. But I'd like to see pics with the rotors on.
Tantum religio potuit suadere malorum. |
Sure, I'll post some after I wash my car today
Woot. :p
I'm still wondering why the goodridge lines only go half way instead of all the way to
the drum and if it makes any difference.
nope.
teflon is gonna expand more than steel brake tubing. the shorter the teflon the better.
#14 | |
Drives: 2007 4 Door Yaris Join Date: Jan 2009
Also, with the stock rotors and pads I had problems with glazing the pads and warping the rotors. So far the R1 drilled and slotted rotors and carbotech pads have lasted longer than stock ever did, and they still look pretty much new. |
#15 | |||
What?
More mass in a brake rotor allows them to absorb more heat over a longer period of time. Talk to Spec Miata racers about brakes. A lot of those guys run the smaller 1.6 Miata brake rotors because they're lighter and every little bit helps. BUT... they can tell the difference between a NEW full-thickness (and thus full mass) rotor and one that is worn down to its service limit. A new full-thickness rotor (with more mass) will dissipate more heat and resist fade longer than it's thinner cousin. Quote:
Holding up for a 2-minute autocross run? I never said ANY brake system wouldn't do that! I said "race track". I'm talking about lap after lap of braking from 90-50, from 70-30, from 80-40... over and over. I'm NOT making this up, I've seen cracked drilled brake rotors at race tracks on everything from Porsches and Audis to Mustangs. Quote:
#16 |
What about just slotted rotors as oppossed to cross drilled and slotted? Any difference there?
#17 |
warping the rotors will relate directly back to poor braking habits.
#18 |
![]() ![]() ![]() Drives: '09 Yaris & '10 Auris Join Date: Apr 2009
Porsche brake discs are not drilled. If i only knew the word in english. The holes are made different, they are part of the production progress but not drilled later.
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
| OEM Yaris brake pad kit PICS | auxmike | DIY / Maintenance / Service | 17 | 11-24-2009 11:42 AM |
| Will XA XB's brake line fit our Yaris?? | AlainMikli | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-04-2009 01:22 AM |
| ALL-NEW PRODUCT LINE: DISC ITALIA ROTORS and PADS | kargoboy | YarisUniverse | 11 | 01-20-2009 04:43 PM |
