warping the rotors will relate directly back to poor braking habits.
#2 | |||||
edit: oh but the bling is totally why I bought them. All the people that pass within 3 feet and catch just the right angle looking through the little hole in my steelies drool in envy of my drilled goodness. |
resident senior
I have to agree with Supmet . D/S rotors do dissipate heat better . More air to more surface area = more cooling . Thats the whole theory behind vented rotors . As far as D/S rotors chewing up pads like cheese graters , false . For your rotors to be grated there would have to be a trailing edge that is raised . ( Go check your kitchen drawer ) . Carbotech pads will decrease the life of your rotors simply b/c they are harder and will grind away more material . Carbotech pads do take longer to heat up which in turn helps the seals in your calipers from melting and also helps to keep your brake fluid from boiling as quickly .
Cracks form from a combination of circumstances . The main one being from a manufacturing defect . When you cast anything , it is virtually impossible to obtain an even thickness throughout . Combine this defect with some heat and poor braking habits and viola ...a crack will raise its ugly head . If there is one crack ( from hole to hole ) that rotor is still usable but you would be wise to monitor for more cracks . I've seen many people do this ( On track ) . If a crack extends from hole to hole to hole , then you need to trash that rotor . If a crack extends from the outer hole to the outer edge then you will get a cheese grater effect from the warpage that will follow . Speaking about on track , I have used the R-1 rotors on track ( against R-1's advice) and they work pretty darn good . The last time I went to Roebling Road . We did 100 + consecutive laps . The Yaris did come in the pits for driver changes but the car never shut off . We experienced no brake problems . Actually the Pros who drove my car said the brakes were surprisingly good . ( I'll get to my secret in a minute ) . We tried our darndest to find a flaw anywhere in the car . The only one we found was lack of power . But the R-1's did glaze up in the mountains . Which is why I bought new rotors from brake warehouse . The R-1's are still good but just wanted to try something else .My brake setup is as follows : Toyota pads , Brake Warehouse rotors , SS lines and ATE Blue fluid . Check the pics below . On the car are the BW rotors . On the ground are the R-1 rotors . Check out the differences . The R-1's have bigger holes and slightly longer slots . The R-1's also have the hole closer to the outer edge . The BW rotors have 2 rows of holes between the slots . The BW have a powder coated hub/hat . The R-1's were zinc plated in its entirety . Both have pointed end slots . The things I don't like about the R-1's are that they took longer to bed in b/c on the zinc plating and they glazed in the mountains ( after turning a pretty shade of blue ) . With a good bit of fade What I like about the BW rotors is that there are more holes , albeit smaller than the R-1's , and the holes are not so close to the outer edge . I also like the powder coating on the hub/hat area . The rust doesn't "bleed" through like they do on the R-1's . I've gotten these rotors a nice crimson color in the mountains with no adverse affects Just a tiny bit of fade . Now for my trick . Notice the R-1s . The one on the right is how everybody else installs their rotors . The holes are slanted towards the rear of the car . The one on the left are slanted towards the front of the car . My theory is that with the holes slanted forward it allows the outer edge to cool first after leaving the pad area thereby producing more consistent results after repeated use . The pros who have driven my car all say the can't believe how consistent my brakes are especially with stock pads . Then I point out my rotor orientation and they go "Hmm interesting" . 6 hours have elapsed since I started this reply to the time I posted . ( GF's Mini broke and I had to go and fix it , Tranny and flat tire ) So I probably missed a few replies .
#4 | |
![]() ![]() Drives: Base 09 White Yaris 3DR 5MT Join Date: Mar 2009
Seems like the people that track their cars have no problems while others choose to speak from what they've "heard".
Proud to purchase parts through
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
| OEM Yaris brake pad kit PICS | auxmike | DIY / Maintenance / Service | 17 | 11-24-2009 11:42 AM |
| Will XA XB's brake line fit our Yaris?? | AlainMikli | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-04-2009 01:22 AM |
| ALL-NEW PRODUCT LINE: DISC ITALIA ROTORS and PADS | kargoboy | YarisUniverse | 11 | 01-20-2009 04:43 PM |
