What?
What do you guys not understand about "I'm not going to argue with you?"
My most compelling reason for "hating" cross-drilled rotors is simply having seen with my own two eyes far too many of them CRACKED at track events. Given the choice between driving on a race track with a rotor that's likely to crack and one that isn't, I'm going to choose the one that isn't. I'm funny that way. Y'all can continue arguing amongst yourselves. |
#2 | |
For the race track, you are probably right. But for street or auto-x use, I really do think they dump heat faster(leading to better brake performance and longer lasting pads and rotors), clear dust, are slightly lighter, and yes - they look better. Plus you can get a pair for $110 from garm, or one stock rotor for $96 from the dealer. I think they are the best bang for the buck rotors for performance and longevity. As far as cracking, I'll never put as much heat in to them as fast as I did when I bed my pads again. If they took that they should be good.I would be interested in some hard testing of the same rotor, same car, drilled and not, infrared thermometer mounted in the wheel well. Surely with some companies making claims of 200 degrees in difference there would be some, but I'm finding it extremely hard to find. |
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
| OEM Yaris brake pad kit PICS | auxmike | DIY / Maintenance / Service | 17 | 11-24-2009 11:42 AM |
| Will XA XB's brake line fit our Yaris?? | AlainMikli | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-04-2009 01:22 AM |
| ALL-NEW PRODUCT LINE: DISC ITALIA ROTORS and PADS | kargoboy | YarisUniverse | 11 | 01-20-2009 04:43 PM |
