![]() ![]() Drives: yaris Join Date: Oct 2008
spark plugs
when do we change the spark plugs?
anybody knows the oem spark plug model of yaris sedan '08? thanks
Half a Bubble Off Plumb
You change them at 100,000 miles.
Captain Slow
Drives: '08 1.5 hatchback Join Date: Dec 2008
There's only 1 brand,2 drive,3 words,4 you: TO-YO-TA |
Yep.
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Apr 2007
the set goes for about $25-$35 depending where you get them from
![]() Drives: 2008 Yaris Hatchback Join Date: Apr 2009
Heard that it may be wise to pull plugs @ say 50,000 miles regap & clean the threads add antisieze to threads & reinstall them if you dont want to buy new ones. This is to prevent plugs from siezing in the heads when you pull them @ 100,000 miles.
They're installed with proper antiseize compound at the factory, and gapping's not recommended with the iridium plugs. It is highly advisable to let the engine cool completely before removing plugs from an aluminum head, and to use a torque wrench when installing the new ones, though these are plugs that use a gasket and thus have some leeway on installation torque. If you ever strip the plug hole threads in the head, though, you'll wish you hadn't.
![]() Drives: yaris Join Date: Jun 2009
do you know the code/name of the spark plug (e.g = bk123456???) both the sedan and the hatchback have the same spark plugs? also do they have the same engine as well? (hatch and sedan) Last edited by _phenoyz_; 06-05-2009 at 11:22 PM. |
^^the sedan and hatchback have the same engine and spark plugs
Any dealer or parts store will be able to get you the right iridium spark plugs |
Google "Yaris spark plugs" and you'll quickly find the part numbers. Yes, the engine is the same in the U.S. sedan and liftback models. 1496cc 1NZ-FE.
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Jun 2006
I had no problems pulling plugs at 80,000 from factory. I did mine a little earlier then 100,000 a my own personal insurance, they looked very good. I will probably change mine again at 150,000.
#12 | |
Personally, I simply changed the iridium plugs on my othe car at about 60k. IMO, if you are going through the trouble of pulling them, you might as well replace them. |
I'm not going to trouble myself to look at them earlier than recommended, as long as it's running OK.
#14 | |
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
What? Nothing! Changing them out before 100,000 miles is a waste of time and money. |
Yep. If you leave plugs in place way past the recommended change interval till they're totally shot, what will eventually happen is that a Check Engine Light will come on with a code for random misfiring. No BFD.
![]() Drives: 2008 Toyota Yaris Join Date: May 2014
I just wanted to come on here and say thanks to you guys for giving me the proper advice to get the job done properly. I'm so impressed I made an account and plan on contributing what little knowledge I have to the cause. This website is awesome.
#17 | |
Mr. 155 and climbing
sent from my m-o-b-i-l-e
Change mine every 30,000 on every car I've owned. Don't care what manufacture says
Sent from my iPod touch using Tapatalk |
| did autolite spark plugs screw up coil or coils ?? | la_scanner | DIY / Maintenance / Service | 20 | 04-09-2009 03:07 PM |
| Where do I buy ngk iridium tip 7 heat spark plugs? | PETERPOOP | Performance Modifications | 23 | 03-08-2009 09:34 PM |
| Upgraded Spark Plugs For Boost | whooppee777 | Forced Induction Forum | 9 | 02-14-2009 02:53 PM |
| Dual ground electrode spark plugs | Kitt | DIY / Maintenance / Service | 15 | 02-09-2009 12:08 PM |
| Spark Plugs | YamilR | DIY / Maintenance / Service | 2 | 09-28-2007 09:38 PM |
