Old 06-29-2009, 02:57 AM   #1
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
If you have a multimeter, check to see if you have current going to the fan with the AC on. If you get current then it is the fan motor. If no current then it could be the sensor or a relay.
You can check the fan motor another way. Connect the fan motor directly to the battery. It should work. If not then replace the motor.
Old 06-29-2009, 03:13 AM   #2
yarisitis
yarisitis's Avatar
Drives: 2008 Yaris LB
Yeah, my brother told me that I could do these things to find out but we don't have a multimeter and I'm hesitant about doing something like connecting the fan motor to the battery myself...
Any idea on how much it would cost to fix any three of these things (motor, sensor, relay) at a dealership?
Also, is the check engine light supposed to turn on if any of those three things (fan motor, sensor, relay) wasn't working because my check engine light has never turned on?
yarisitis is offline   Reply With Quote
Old 06-29-2009, 06:10 AM   #3
R2D2
Crazy Oil Sniffer
R2D2's Avatar
If your not comfortable testing these things yourself take the car to the dealer or a trusted shop-it'll probably be cheaper than trying to guess.
Otherwise go buy a decent multimeter and test! The multimeter will pay for itself pretty quickly-consider it an investment, and you'll have it for any future electrical issues that may arise. The folks on the forum here are very helpful and will be a great resource-you've already been given some good advise with diagnosing and how to proceed.
Whatever you choose, good luck! Let us know how it turns out!
R2
Old 07-01-2009, 12:31 AM   #4
silver_echo
ekodrvr
silver_echo's Avatar
how many miles are on the car? for age, it would still be under warranty... if it is still under warranty, i would think that it would be covered...
i like this smiley...
silver_echo is offline   Reply With Quote
Old 07-01-2009, 12:33 AM   #5
yarisitis
yarisitis's Avatar
It's a 2008 3-door with 8k miles. I bought this car salvaged so it is not under warranty...
Cold air intake vs air intake Liu997 Performance Modifications 15 11-05-2009 05:32 PM
Simota Carbon Charger Cold Air Intake lilredrocket Performance Modifications 18 04-13-2009 03:16 AM
