Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
Changing the oil exactly on schedule is not the issue. It's abuse and not doing regular maintenance. Changing early or late will not void the warranty.
Half a Bubble Off Plumb
Within reason. Back in the '70s and '80s when Mobil 1 was advertising extended drain intervals, I'm sure I damaged two engines by blithely following them. I don't believe in extended drain intervals with any oil now, and if you're going to be changing at the recommended intervals, I don't believe there's any real advantage to using a synthetic oil unless you're operating in extreme Arctic cold.
#3 | |
MORDSITH
Drives: 2007 Yaris Hatchback Join Date: Apr 2006
Im out of warranty now (at 3.5 years), and even though I plan to continue still going to the dealership at every 8,000km or 6 months (whichever comes first), I may still purchase some Redline synth oil and have them replace it with that when I go in for my next service appointment at Toyota. Can anyone comment on that improvement if one switches to synth from reg oil, but still takes their car in every 8,000km/5,000 miles?
2007 Yaris Hatchback 5 Door LE, Manual, Package B, Bayou Blue Metallic |
| best synthetic oil and m/t oil?? | doodoo | DIY / Maintenance / Service | 122 | 04-03-2017 08:43 PM |
| Synth Blend Oils | scape | DIY / Maintenance / Service | 7 | 07-12-2009 01:55 PM |
| Synthetic Oil | Kaotic Lazagna | DIY / Maintenance / Service | 122 | 09-20-2007 03:40 PM |
| When to switch to synthetic oil? | jay | DIY / Maintenance / Service | 65 | 02-15-2007 08:44 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
