Half a Bubble Off Plumb
Within reason. Back in the '70s and '80s when Mobil 1 was advertising extended drain intervals, I'm sure I damaged two engines by blithely following them. I don't believe in extended drain intervals with any oil now, and if you're going to be changing at the recommended intervals, I don't believe there's any real advantage to using a synthetic oil unless you're operating in extreme Arctic cold.
| best synthetic oil and m/t oil?? | doodoo | DIY / Maintenance / Service | 122 | 04-03-2017 08:43 PM |
| Synth Blend Oils | scape | DIY / Maintenance / Service | 7 | 07-12-2009 01:55 PM |
| Synthetic Oil | Kaotic Lazagna | DIY / Maintenance / Service | 122 | 09-20-2007 03:40 PM |
| When to switch to synthetic oil? | jay | DIY / Maintenance / Service | 65 | 02-15-2007 08:44 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
