Old 07-15-2009, 09:34 PM   #1
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
i got an 09 cluster. there were no problems installing it at all, it was very easy and took about 10 mins or less and you only need a phillips head screwdriver.. ill take a pic later tonight for you guys and post a pic of the box with the P/N.
mikenacarato is offline   Reply With Quote
Old 07-15-2009, 09:49 PM   #2
Interesting. The 09 service manual doesn't mention anything about reprogramming. In the replacement procedure it does mention disconnecting the battery (but then again it does for replacing anything electrical).
You may want to try for the heck of it disconnecting the negative battery cable for a couple of minutes to see if perhaps on a cold boot the ECM and the combination meter do some type of a sync.
DIY Oil Pressure Gauge Install LtNoogie DIY / Maintenance / Service 13 11-20-2009 04:13 PM
A-pillar gauge pod Tonavi Cosmetic Modifications (Exterior/Interior) 26 02-26-2009 07:35 AM
Yaris safety pack - where is it located? signs General Yaris / Vitz Discussion 5 02-22-2009 06:43 AM
A-Pillar gauge pods that can fit tweeters? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 9 11-23-2008 02:25 PM
Gauge Pod for Liftback? eight_heads General Yaris / Vitz Discussion 2 06-07-2007 10:41 AM
