Old 02-23-2009, 05:42 PM   #1
Tonavi
Tonavi's Avatar
Drives: 2007 Yaris HB
A-pillar gauge pod
I promised I've searched for hours and haven't found anything on this!
I installed an AutoMeter 3-3/8" tachometer and now want to add water temp and maybe oil temp gauges, too. I'd be doing an a-pillar pod.
Before I buy anything, I want to know how the water and oil temperature gauges are installed. The tach was easy; it plugged right into the ECU. I'd think that the water temp would be the same way since it's monitored by the computer. For the oil temp, there must be a sensor that I can tap into for a reading.
Has anyone installed a water oil temperature gauge (NOT the Scan Gauge) in their Yaris, and how did you do it?
I'd love to see pictures if possible.
Thanks YW!
Tonavi is offline   Reply With Quote
Old 02-23-2009, 05:53 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
i'm pretty sure there is no oil temp sensor in the yaris..
you'll need to tap the head for that
Old 02-23-2009, 06:00 PM   #3
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
couldnt you get a sandwich adapter at the oil filter?
Old 02-23-2009, 06:22 PM   #4
Tonavi
Tonavi's Avatar
I'll probably forgo the oil temp if it would be that big of a job. If it were a simple wire tap I'd do it. Instead of that I'll look at maybe doing an exhaust temp or something less intrusive.
Has anyone done a gauge pod though?
Old 02-23-2009, 06:23 PM   #5
33OH
Drives: '08 Yaris
I have a gauge pod sitting next to me in my room right now, but it's for 2 1/16th gauges.
Old 02-23-2009, 06:34 PM   #6
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
Thanks YW!
im sure theres a stock water temp sensor you could tap into. or u could get an adapter and cut into a coolant line and stick the adapter and the gauges sensor into that. u'll have to drain ur coolant if u do that.
y do u want oil temp?
oil pressure would be more useful. and a sandwhich plate would make this a very easy install. when u go to change ure oil before u put the new filter on u stick the sandwhich plate on and then the filter goes on the sandwhich plate. the sandwhich plate from glowshift has like 3 or 4 places to plug in a pressure sensor, oil temp sensor, and u could even add lines for an oil cooler if u wanted
Old 02-23-2009, 06:36 PM   #7
1NZYaris1
1NZYaris1's Avatar
Why not just put in a scangauge or something similar .
Old 02-23-2009, 06:37 PM   #8
whooppee777
u mean like this one?
Old 02-23-2009, 06:41 PM   #9
Tonavi
Tonavi's Avatar
Yeah that one looks nice.
I'd want oil temp because it tells you more about the engine than the water temp does. Oil pressure would be useful, too, but it would always be constant (why put in a gauge that will never move?). My next idea would be a vacuum gauge to fill the pod.
Old 02-23-2009, 06:44 PM   #10
Tonavi
Tonavi's Avatar
They aren't as easy to read instantly and since I already have the tach, I'd like to maintain that same style. I like how much info the scangauge tells you from one port, though. Do you know if there's an alternative that's just as useful?
Old 02-23-2009, 07:05 PM   #11
whooppee777
uhm so when ur oil pressure goes to shit and u know when exactly it happens so that u can turn off the engine before it destroys itself.
seems like a good reason to me.
my volt gauge came in handy this weekend when my belt came off the pulleys and i saw the volts drop and i stopped the car even before the ecm knew anything had happened.
Old 02-23-2009, 07:10 PM   #12
1NZYaris1
1NZYaris1's Avatar
Your probably right there , and i must admit , the above pictures look bloody awsome
would love to do something similar , but as it is the wifes car and my toy ,
a comprimise is what i have to deal with ,
as in her words it's like seating in a fighter plane cock pit . to much to look at .
Old 02-23-2009, 07:19 PM   #13
whooppee777
Originally Posted by camelll View Post
The oil pressure in this car varies wildly. It is not always constant. It fluctuates with the rpm of the vehicle, mine varies from 20 psi to 80 psi. Anyways here is my gauge pod.
i like urs better than mine.
yea i forgot that it does that mine moves all the time and i dont even notice anymore.
it will definitely move more than a temp gauge.
Old 02-23-2009, 07:24 PM   #14
Tonavi
Tonavi's Avatar
Not that oil pressure isn't useful, but as long as it's above zero (or 20), that's a good sign. I check the oil level every time I fill up, so I'd know well in advance if I am running low. Since most oil pumps work with a straw that faces down toward the oil pan (the pickup), as long as the oil is over that straw, you'll have full pressure.
Oil temp is more useful because it tells you if your car is cold or is truly overheating. For example, a Saturn (a great oil burner) would burn all its oil off, but the water temp and oil pressure gauges would remain the same. An oil temp gauge would tell you how hot your engine is running when water doesn't tell all.
Old 02-23-2009, 07:27 PM   #15
Tonavi
Tonavi's Avatar
How did you wire the gauges? Did they go directly to the ECU?
Old 02-23-2009, 08:35 PM   #16
No. If you have a leak, you lose pressure before you lose all your oil. That's why a pressure gauge is valuable; it gives you time to pull over and shut down the motor (hopefully)
Old 02-23-2009, 08:42 PM   #17
Tonavi
Tonavi's Avatar
In my friend's GMC Yukon (with oil pressure gauge), there was a leak at the oil pan gasket and rear main seal. Gradually, the engine lost its oil, with no change in pressure. Finally, the engine seized when we were on the highway, yet in it's last few breaths, the oil pressure still read 45-50 before reading zero. He knew enough about cars to stop if any of the gauges went into the red zones, too.
Old 02-24-2009, 09:28 AM   #18
Tamago
Tamago's Avatar
Drives: UZJ100
if you want oil pressure, get it from the same place the stock ecu gets it.. on the front of the engine.
A-Pillar gauge pods that can fit tweeters? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 9 11-23-2008 02:25 PM
ebay a pillar gauge pods KSIbucky Cosmetic Modifications (Exterior/Interior) 2 07-16-2007 11:47 AM
a-pillar gauge pod 07typeS Cosmetic Modifications (Exterior/Interior) 36 06-17-2007 08:53 AM
Gauge Pod for Liftback? eight_heads General Yaris / Vitz Discussion 2 06-07-2007 10:41 AM
