Old 07-20-2009, 09:36 AM   #1
Lewis
Our off road vehicle
Lewis's Avatar
Drives: 2009 Yaris 3dr
Question instrument cluster-TACH "S" model
A humorous situation exists IMO regarding the Instrument cluster on the 2009 models that happens when marketing, not engineering drives product- a noted Toyota foible.
You can only get a tachometer in your OEM instrument cluster (persumably because it's the better grade car) on the S model.
The problem is that the S model now only is available (per the Toyota website) on the 5 door hatchback which itself only comes with an automatic.
Sooooooooooo........if you have a manual transmission - where you could use the tach- you can't get a tach- but if you spring for the S model- you get a tach - which is essentially useless- because it only comes with an automatic transmission!
I discovered this silly situation when I attempted to buy the cluster from the 2009 S from the dealer and discovered the cluster would only be compatible with an automatic transmission Yaris!
Great judgement marketing department!!!!!!!!!
Lewis is offline   Reply With Quote
Sedan Instrument Cluster to LB Instrument Cluster Malaya1221 Cosmetic Modifications (Exterior/Interior) 2 12-02-2008 10:05 PM
Instrument Cluster Swap thepaidtraveler Cosmetic Modifications (Exterior/Interior) 28 11-24-2008 09:53 AM
"S" cluster in non s car? mikenacarato Cosmetic Modifications (Exterior/Interior) 43 11-17-2008 08:45 AM
instrument cluster swap S -> LB elo79 Performance Modifications 1 12-21-2006 10:22 AM
