Old 11-03-2008, 12:03 PM   #1
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
"S" cluster in non s car?
Is it possible to swap the cluster from the "S" or the sedan into the cars without the tach. I would really like to add a tach but want to go the most oem look as possible.
Old 11-03-2008, 12:06 PM   #2
Stargate YARlantIS
Stargate YARlantIS's Avatar
I'm wondering about this myself....they both seem to be the same size
Visualize whirled peas.
Peace, Love and Good Smoke!
--Tommy Chong
Stargate YARlantIS is offline   Reply With Quote
Old 11-03-2008, 12:27 PM   #3
JosephDoc
Drives: 07 Yaris 3D
Same here!! I would get one if it works, but another question I have is about how the odometer will get the mileage programmed.
There is a related thread about this but it seems no one confirm with 09’ s-model in USA.
JosephDoc is offline   Reply With Quote
Old 11-03-2008, 02:43 PM   #4
mikenacarato
SIPNDEW
Drives: 15 STI
the mileage isnt stored on the cluster, its stored in the ecu. ive swapped the cluster out on my volvo before which was all electronic so i bet you can do it too the yaris. i bet a cluster isnt cheap though.
Old 11-03-2008, 02:45 PM   #5
hatchbackkid82
Drives: .
i thought this was beat to death before tha hack
Old 11-03-2008, 03:04 PM   #6
PaidTimeOff
OMGWTFKITTYKATMEWMEWMEW
Drives: 2008 Yaris S
it was, and I believe the consensus was that it is not plug and play. You could probably get a cluster and wire it if you're familiar with the wires in the dash.
PaidTimeOff is offline   Reply With Quote
Old 11-03-2008, 04:01 PM   #7
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
I believe it fits physically but it is a PITA to wire.
Old 11-03-2008, 07:29 PM   #8
My Scion tC stores mileage data in the cluster. So I don't know about the Yaris.
Old 11-03-2008, 07:35 PM   #9
darthbauer
Not really here...
darthbauer's Avatar
I think before the hack they also figured out that it was stored in the cluster.
Also the price for a new S cluster ended up being around $500.
Liberate Tutemet Ex Infernis.
Old 11-03-2008, 07:51 PM   #10
frodos
Drives: Yaris hatchback
but the US liftback doesn't have tach will that work ? mine have it but is all digital
frodos is offline   Reply With Quote
Old 11-03-2008, 09:17 PM   #11
i thought it was all already been over that it works?
if you get a LB cluster with tach will work on all other LB. same for sedan.
and the mileage is stored in the cluster
Old 11-03-2008, 11:32 PM   #12
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Sedan cluster will NOT fit an LB. An Lb 'S' cluster should plug and play with a non 'S' LB, but good luck finding one. And supposedely mileage is stored in both the ECU and cluster...
Old 11-03-2008, 11:51 PM   #13
PaidTimeOff
This plug and play suggestion is from experience? Because from what I remember some people looked in to this prehack and came to the conclusion that it would require wiring...
Old 11-03-2008, 11:59 PM   #14
PetersRedYaris
No, I thought someone on here had done it, or at least compared the two side by side. If I am wrong I will happily delete the post...
Old 11-04-2008, 01:26 AM   #15
mikenacarato
SIPNDEW
Drives: 15 STI
well it shouldnt be a problem finding one, the dealer should be able to get them. if its plug and play then i may do it
Old 11-04-2008, 11:50 AM   #16
||)) (o) ||\||
- Donnie Demonic -
||)) (o) ||\||'s Avatar
Drives: '07 Yaris Sedan Sport
The mileage is contained in the cluster. I bought a second project cluster on eBaY and whenever I hooked it up, the lcd said my mileage was 16,000+. I only had like 12,000 miles on my car at the time.
||)) (o) ||\|| is offline   Reply With Quote
Old 11-04-2008, 12:24 PM   #17
mikenacarato
SIPNDEW
Drives: 15 STI
did it work?
Old 11-04-2008, 02:08 PM   #18
PetersRedYaris
Yeah, I meant finding one for cheap would be difficult. Although maybe more wrecked Yarii S's are showing up at salvages...
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 09:08 AM
Car doors are not self-locking when left unlocked fainty_girl General Yaris / Vitz Discussion 27 03-14-2011 09:12 AM
Someone Please Help With SET & Local Dealer Nightmare! sanityassassinv2 General Yaris / Vitz Discussion 32 11-26-2008 11:32 AM
11/02/08 Metro Auto Squad 1st Annual Car Show (my car club) Jerkratt NY / NJ/ CT / PA 14 10-26-2008 05:51 PM
How to Be a Street Racer - General Life Guide MDF Off-topic / Other Cars / Everything else Discussions 7 03-19-2007 12:49 PM
