XBL: Jeemee Ghost
I have found numerous 08 manual gauge clusters with tachs on eBay. Some of you may wanna check there too.
_________________________________________________ Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
^^ I'm not sure if those work with the 09s though. For the amount of money is costs, I'd rather be certain it works for my car.
╚══════════RN
Wow, this is great!
Our off road vehicle
Drives: 2009 Yaris 3dr Join Date: Apr 2009
this seems to be a tough nut to crack ;-(
Beast
so your saying automatics can easily swap for a cluster with a tach in it?
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
![]() ![]() ![]() Drives: Silver 2007 3Dr - Gryph Join Date: Jul 2007
Long story short: You can freely swap clusters between *LIFTBACK* Yaris models, from the 2009 S-model all the way back to the 2007 stripper-model.
Previous folks verified that you can swap the cluster from a 2009 S-model liftback into a 2009 Manual non-S liftback. The S-model is an automatic, so that verifies Automatic/Manual swappability. I just verified that you can swap a 2009 MT non-S liftback w/ ABS cluster into a 2007 MT non-S liftback *WITHOUT* ABS, and that still works. This verified being able to swap a cluster with ABS hookups into a vehicle without ABS, without causing an ABS alert. It also verified that the red/amber clusters in 2009's are interchangeable with the blue/white clusters from 2007's and 2008's. Combine these two, and you can freely interchange basically all United States Liftback Yaris clusters. The connectors are the same, and 'extra' indicators don't appear to default to a fault state, they simply read 'no such device' and stay shut off. The obstacle is this: Toyota requires a VIN and current-odometer reading to ship a new cluster out, due to fears of odometer fraud because by default the cluster stores it's own copy of the odometer. The ECU also stores a copy, but the ECU can't over-ride the cluster without Toyota plugging their 'magic cables' in to re-sync them. Getting 2009 S-model clusters is the best bet for adding an OEM-style tachometer to earlier Yaris Liftbacks. Someone'll need to approach Toyota more directly than at the dealership level most likely it looks like to get these parts for those of us that want to do the upgrade, myself included.
JDM Fred
I tried searching for the 09 s gauge cluster and the part # didn't work. What's the deal with that?
![]() ![]() Drives: 08-2DR-MT-LB-Red Join Date: Jan 2009
In all my life I have never driven a manual transmission without a tach. Shame on Toyota for not including a tach. My 08 3dr MT base model came with a tach. Maybe that's because I'm in Canada??
To all those interested in swapping for an 09 "S" gauge cluster: go to Google and type in 'junk yards'. Most of the websites that are listed will have a form where you can input all the info for the part you're looking for. Be sure to specify '2009' and 'S' so you don't get stuck with an 06 cluster with no tach. Most of the junk yards responded to my parts request in less than 24 hours, either by phone or email.
Nearly every junk yard I contacted by phone and/or email had at least one of these clusters in stock for purchase and none were more than $300. Good luck! |
![]() ![]() ![]() ![]() Drives: 2008 meteorite hatchback Join Date: Nov 2008
I just received a tach gauge cluster today from a CDM 2006 automatic model. My car is a manual, fyi. Plugged it in today and it worked without any problems. The mileage wasn't updated, but whatever. No lights came on, and there were no other problems. Not bad for $110 shipped!
- HOOOEY! That's one tahny little cawr! What the heck kinda toy is that? - A Toyota Yaris - A whut Yaris? Last edited by mrbond; 12-24-2009 at 05:52 PM. |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite 3dr Join Date: Jul 2009
not bad at all for $70. good find!
Touchscreen DVD Navigation - 10" Bazooka Subwoofer - Kenwood Speakers - Toyota Premium Horn set AFE Pro Dry Air Filter - modified air intake box - 1ZZ-FE Throttle Body - Ultra Racing Rear Sway Bar & Front Strut Bar NST in cabin & engine bay SSK's - TWM shifter base bushings & cable bushings - Megan Racing C-Pillar Brace |
Another side-effect of swapping to the '09 S-model cluster: That one has a Cruise light since the S-model also forces you to get all the power-crap IIRC.
So anyone retrofitting 'factory' cruise to their '07 or '08 may be able to get the dash-light with this swap as well. As I'm going to be 'migrating' the cruise-control stalk and what-not from my friend's '09 to my '07, I'll swap the cluster when I do that and update folks on how that works as well.
╚══════════RN
Yes, please keep us updated on that project - make a new thread for it, that would push me over the edge into buying a new cluster and cruise control kit.
Interested also as long as it is plug and play.
lol there's the MPH reading right under the KPH reading. Took me a couple of hours to learn where to look. No biggie.
- HOOOEY! That's one tahny little cawr! What the heck kinda toy is that? - A Toyota Yaris - A whut Yaris? |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
I don't know if I am ambitious enough to do a IP cluster swap, but I had a lead on one
at a scrap yard in the state. Just checked online, and it's not listed anymore. Maybe someone from here grabbed it?? ![]() I didn't even get a chance to call on what the price would be. |
Swapping the cluster is literally a five-minute job. You only need a philips screwdriver to do it.
You pull off the two pieces of side-trim on either side of the radio, pull the trim from the cluster (forward towards the radio, not up) then unscrew two screws. Lift and slide the whole cluster out, unplug the two cables. Reinstall the reverse: Plug cables in, slide into place, put screws back in, clip the bezels/trim back in place, done. It's easier to do this than to put your spare tire on or change your own oil. And it's 100% plug-and-play across Liftback models.Hell, I'll be frank: This is as fast if not faster than taking the radio out, I'm surprised crooks aren't smash-and-grabbing them since there's nothing stopping it as far as I can tell.
just take the ABS LED out!...maybe?
| Sedan Instrument Cluster to LB Instrument Cluster | Malaya1221 | Cosmetic Modifications (Exterior/Interior) | 2 | 12-02-2008 10:05 PM |
| Instrument Cluster Swap | thepaidtraveler | Cosmetic Modifications (Exterior/Interior) | 28 | 11-24-2008 09:53 AM |
| "S" cluster in non s car? | mikenacarato | Cosmetic Modifications (Exterior/Interior) | 43 | 11-17-2008 08:45 AM |
| instrument cluster swap S -> LB | elo79 | Performance Modifications | 1 | 12-21-2006 10:22 AM |
