Old 07-21-2009, 10:16 PM   #1
Check the fuse to see if the switch popped it. Many of the aftermarket fog switches are not compatible with the "use the oem wiring" method without modification to the switch's circuit board.
Old 07-21-2009, 10:28 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
He's useing the OEM light / foglight stalk , according too his first message .
Old 07-21-2009, 10:34 PM   #3
Totally missed that. In that case, Is the fuse in the correct slot and do you hear the relay click when the headlights are on and you turn the fog switch on?
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
Part #s for Fog Light install? Can anyone who works for Toyota confirm? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 73 12-23-2010 05:15 PM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 08:25 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
