Old 07-22-2009, 09:36 PM   #1
Vince87
Drives: 2007 2DR Yaris
I've already tried that.... And the on/off switch I'm speaking is the one before the resistors and were the pin40 and ground wires are attached...
Vince87 is offline   Reply With Quote
Old 07-22-2009, 09:44 PM   #2
I had missed this above:
"I did check the extra switch with the meter before doing the swap and they were ok (0 resistance when unpressed, high value (1) when pressed)... "
This indicates that the switches are the wrong type. They are normally closed, rather than normally open switches. Unpressed should be high resistance and pressed 0 resistance.
Old 07-22-2009, 09:56 PM   #3
Vince87
Wow ! I thought that normally open switches were "normally" allowing current to flow but it seems to be the opposite... sorry for that I should have checked by myself before... Thanks a lot !!!
Old 07-22-2009, 11:06 PM   #4
texkid
The one with cheese on it
Drives: '10 Corolla S
I am not sure if I found the right one on eBay??
This is what I am going by in my search for the switch......from the first page.
This is the closest thing I can find.....and here is the LINK to the eBay listing
So did I find the right one?
Or can someone please send me towards the right direction, perhaps?
DIY: A/C Insulation
texkid is offline   Reply With Quote
Old 07-23-2009, 07:02 AM   #5
That will work.
That listing doesn't have a part number listed, but the correct part number is: 84632-34011
On the Camrys the same stalk as the Yaris one was used from 04 to 09.
In the picture on that listing the wire that goes from the switch to the connector on the spiral cable is missing. Part number for the wire is 84633-42030 and it goes for about $30 from the dealer.
Old 07-23-2009, 11:34 AM   #6
texkid
That will work.
Thank you very much. I just made an offer to the seller. In the meantime I will keep on looking around to see what else i can find.
Added Note:I was just on TRDSparks.com, their website is stating that part number 84633-42030 is being replaced with part number 84633-02020. I am not sure if that is correct so I thought I give ya'll a heads up.
DIY: A/C Insulation
Old 07-23-2009, 12:06 PM   #7
84633-02020 is shown in the EPC as being for the 08-09 Corolla and Matrix, but perhaps it is the same, so they are merging the two part numbers.
By the way, in looking for stalks, ones from the following vehicles are all the same:
Camry 04-09
ES300 04-09
Scion TC 04-09
Sequoia 04-09
4Runner 04-09
Corolla 08-09
ES350 06-09
FJ 06, 08
GS450H 06-09
GX470 04-09
Highlander 04-09
IS F 07-09
IS250 05-09
Land Cruiser 04-09
LX470 04-09
LX570 07-09
Prius 04-09
RAV4 04-09
RX330 04-09
RX400H 05-09
Scion xB 07-09
Scion xD 07-09
Tundra 04-09
The 84633-42030 wire is supposedly only used on the following vehicles:
Corolla 08-09
RAV4 05-08
Yaris 06-09
Old 07-24-2009, 08:21 AM   #8
Vince87
Just drove to work with my newly working cruise control, this is amazing ! thanks a hundred times CTScott ! So it's now confirmed that the mod works on the Canadian model of the yaris (mine is a 07 MT liftback)... Next step is to install the Clutch Switch and the On/Off LED !
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
