Old 07-23-2009, 09:59 PM   #1
ztlonewolf
ztlonewolf's Avatar
Drives: 2008 red 3 dr S coupe
here's something you can try,when your car is cold,take off the cap,start the car and fill the radiater while the car is running,let it run until the thermostat opens up,the coolant level will drop,put in more coolant (just enough to fill it up to the top),once the coolant level starts to rise,put the cap back on the radiator and run it.that should take care of any air bubbles that may be in your system,once the car is cold again,check your levels and see if that helped.
ztlonewolf is offline   Reply With Quote
Old 07-23-2009, 11:05 PM   #2
CB900F2
Drives: 08 Sedan
Thanks wolf I will give it a try..
But the funny thing is my fluid level in my overflow bottle will rise about 1inch when the coolant becomes hot, and will also then lower when the engine cools off...so it seems fluid is flowing between the system and the overflow bottle..
thanks again!
Old 07-23-2009, 11:40 PM   #3
Snappy
Drives: 2 Yaris Hatchbacks
When the engine is cold, try squeezing the upper radiator hose. I had a bad cap, and the same low fluid problem you have on one of my two 2007s. When you squeeze the hose, see if you hear/feel the air compressing in the filler neck, I got some give then a faint click. I replaced the cap (cheap for a Toyota part!) and no more problems. Also, I could squeeze the hose with the cap off, bringing the coolant level up to the top, then put the cap on, but when I checked again after driving and letting the car cool down, the low level returned.
Snappy is offline   Reply With Quote
Help ASAP!!!! low coolant indicator MeggiemobileSFLA DIY / Maintenance / Service 29 08-03-2013 01:09 AM
Coolant Service N9QGS DIY / Maintenance / Service 31 11-27-2012 06:55 AM
Coolant level when engine cold CB900F2 DIY / Maintenance / Service 4 04-05-2009 11:12 AM
Proper coolant level? jay DIY / Maintenance / Service 4 03-22-2009 04:23 PM
GET FREE PS3/360/Wii check it out! marcus Off-topic / Other Cars / Everything else Discussions 23 09-25-2007 06:51 PM
