#19 |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
*nod* We have all found the same thing. The bars are not entirely consistent, and the top half of the tank lasts longer (according to the gauge) than the bottom half does.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#20 | |
Pretty green Yaris Verso
Drives: Toyota Yaris Verso Join Date: Mar 2009
#21 | ||
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
#22 | |
Here ya go... http://www.youtube.com/watch?v=TuEdU_lrtZk Classic!
#23 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
![]() Cheers! M2 |
#24 |
I just filled up after 40 miles of the last bar fast blink. It was my first fill up. 510 miles and 11.009 gallons. $1.99.9 per gallon. 46mpg! not bad for my first tank of gas.
#25 |
![]() ![]() Drives: 07' HB Black Join Date: Nov 2008
I got 160 miles out of my last tank .... guess its the intake header and exhaust .. or I must have something severly messed up in my car
When life passes you by ... dowshift
#26 |
Half a Bubble Off Plumb
The problem's usually with a loose nut behind the pedals.
#27 |
That used to be my problems, but I decided to quit speeding, so with this tank I havent been over 60 ... except that one moment where I did 80 but it was barely 2 minutes
#28 |
Yeah, it's possible that changing the intake and exhaust could mess up your ECU calibration. I'd expect to see a Check Engine Light, though. Hot rod mods tend to inspire the rodder modder to use them, and zooming off from stops and hitting the brakes for the next one will suck the tank dry.
#29 |
![]() Drives: 09 3D Liftback Join Date: Jun 2009
Oddly enough, wanted to find out as well, and I did today. As soon as the last bar started flashing I drove approx 1 mile and filled up. Took 9.959 Gallons. So for myself at 1.1 gal left I could go about 37 miles to empty. I have a bit of a heavy foot, but still get 34 mpg, with rarely any highway and running A/C. All good as far as Im concerned coming from prior performance oriented vehicles. Of course this is my deduction for my driving style. Love this vehicle.
#30 |
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Apr 2009
I've gotten 76 miles on my first bar, 37-57 miles on the middle bars, and 80 miles on the last bar.
Not very consistent. |
#31 |
![]() ![]() Drives: 08-2DR-MT-LB-Red Join Date: Jan 2009
I pulled into a gas station almost immediately after last bar started flashing. I filled up and it turned out there was 4.5 litres left in the tank. At a rate of 6.5litres/100km (city) and 5.5litres/100km (highway) thats just 70 km in the city and 81 km on the highway. I haven't pressed my luck so far - but I did travel ~55km on the highway @110km/kr with one bar left. Based on what I've read above...maybe I did try my luck.
Who knows. With up-to-date oil changes, clean air filters and good air pressure in the tires you should get great gas mileage. |
#32 |
Scrubble with a poke.
Drives: 2009 Yaris LB Join Date: Jul 2009
Mine acts the same way, I thought that it started after I out the rims on though. When I was still running the facotry wheels and tires I could get about 100 miles out of the first bar.
"If you cannot find truth right where you are, where else do you expect to find it?" Dogen |
#33 |
Gas Saver
Drives: Toyota Yaris Hatchback Join Date: Oct 2008
you will blow your pump out if you put to much stress on it, letting your fuel get so low. Personally, I think its smarter to fill up before then last bar. As its like 300 bucks for the part + install.
#34 |
So I've been driving for over 30 years, have owned several cars for almost ten years each, I have always allowed the gas to run low, and I have never repaired a fuel pump yet. Nor do I know of anyone who has had to do so that does the same. So please excuse me if I don't take your comments as fact!
#35 | |
Is now a Corolla S Owner
You probably didn't listen when your mom told you to change your underwear every day in case you were in an accident, told you not to play with sharp sticks because you would poke your eye out, and told you to stop making faces because your face could freeze like that. Well, Mister, when you find yourself in the hospital with one eye, a frozen face, and wearing dirty underwear, remember that your mom tried to warn you .
#36 |
Captain Slow
Drives: '08 1.5 hatchback Join Date: Dec 2008
last blinking bar of mine = 50km
There's only 1 brand,2 drive,3 words,4 you: TO-YO-TA |
| DIY - rear sway bar [pics] | cali yaris | DIY / Maintenance / Service | 199 | 07-28-2022 06:25 AM |
| DIY: Strut Tower Brace Bar | redyaris | DIY / Maintenance / Service | 18 | 03-16-2014 07:52 PM |
| Rear Sway Bar Instructions - Additional Pics | SeaYa | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 02-26-2009 02:05 PM |
| solid torsion bar bushings... the best rear anti roll upgrade | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-06-2008 12:37 AM |
| c one motorsport performance bars | badhabitz | Performance Modifications | 17 | 08-23-2006 11:31 PM |
