#1 |
![]() Drives: toyota yaris Join Date: Feb 2009
The last bar of petrol
How far can you drive when you reach the last bar when it starts to blink? I'm a paranoid driver and the most I've gone when it starts to blink is 10kms, and then I fill up.
I was wondering - can the last bar take you as far as the other bars (which, averages to about 70-80kms per bar for me). |
![]() ![]() ![]() ![]() ![]() Drives: '08 LB MT Bayou Join Date: Oct 2008
When the last bar flashes slowly you have 1.6 US gals. left - when it starts flashing faster you have 1.1 US gals. left.
#3 |
Audio Junky
i've done 50miles after blinking started.... if it ACTUALLY goes off at 1.6g then I should be able to do 60ish miles. I try to get gas though within ten miles of the blinker starting as I don't care to put more stress on the pump/filter and any other parts that supply the gas to the engine... Plus... humidity is high over here.... more air in the tank = more water in the tank.
#4 |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
I'll usually see how far I can go before the blinking speeds up, after which I keep a sharp eye out for the next station
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
#5 |
![]() ![]() ![]() Drives: 2010 Carmine Red hatchback Join Date: Mar 2009
Why not fill up when it starts blinking, find out how many gallons (liters?) of fuel it takes to fill up then subtract that from 11.1 gallons (42 liters?). Then figure out your fuel economy and extraopolate how far (at least theoretically) you could have gone on the remaining gas that was in the tank when you filled up.
Example: last bar starts blinking and you immediately fill up. You put in 9.5 gallons and drove 350 miles. 11.1-9.5= 1.6 gallons 350/9.5= 36.84 MPG 1.6 * 36.84= 58.94 miles You could have (theoretically) driven another 50-60 miles before running completely dry. This assumes that you can eek out every last drop of gas from the tank.....not sure how low the Yaris will go. To be honest with you, on every car I have ever owned I purposely ran out of gas once, just so I could see how far I could go before running out (I had a gallon of gas with me, of course). That way if I ever found myself low with no stations around I could figure out about how far my range was before running completely out. Just a thought. YMMV though (pun intended)! :) |
#6 |
![]() ![]() ![]() Drives: 08 LB BLACK Join Date: Oct 2008
What is the purpose of waiting for blinking to increase? Why not fill when you get down to last bar?
#7 |
![]() ![]() ![]() Drives: 2008 Yaris Liftback Join Date: Oct 2008
To each his own. I get nervous as soon as the thingy starts to blink and go fill up. That's prolly why they designed it that way. But at least I know I have around 60 miles to travel to get comfortably to a station. hehehe
#8 | |
I really LOVE this car!!!
Drives: 08 Bayou Blue LB AT Join Date: Oct 2008
Drove husbands car on a short road trip the other day. Didn't realize he had almost no gas. By the time I could get off the interstate and to a gas station it was doing the fast blinking thing and had been for a few minutes. I was getting concerned as it was 11:00 at night and I was on the interstate an hour from home by myself. Oh, FYI it took 10.293 gallons to fill it up. |
#9 |
wow, 50-60 miles is pretty good. That's roughly the same as the other bars. That's really good to know. Now I know that I don't 'have' to fill up when I leave my house for work at 7am in the morning and rush to work - there is enough to take me to work. Kewl. Another reason I love the yaris
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
Heck, you people don't know how to live! Don't let your lives be driven by the blinking light, be like Kramer on Seinfeld and see how far you can go on a tank of gas!
#11 |
Joey
Because someday I want the AAA tow-truck guy to think to himself "I can't believe I'm filling up a Yaris... How much MPG does it get again?"
#12 | |
![]() ![]() ![]() Drives: 2008 Sedan A/T Silver Join Date: Nov 2008
#13 |
Beast
yeah... lately when my last bar starts blinking... within 30 miles my car has stopped running... Its horrible =D...
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
#14 |
My car is a bit odd. It goes from 2 bars to blinking. I'm not sure why it seems to skip the last bar.
I tend to tell myself I'll fill up when it gets to two bars, but I always wind up forgetting and then panic when it starts to blink. But I always fill up for less than 10 gallons so I know I still have quite a bit of gas left. |
#15 | |
As with all things YMMV. |
#16 |
Nothing beats a Toyota!
Drives: 2013 Yaris 5 dr liftback Join Date: Jan 2009
I wonder if the 09's are different. Mine goes from two bars to a blinking one bar.
Big Dave Indianapolis, IN Synthetic Oil....its in my car.....for at least 10,000 miles! ![]()
#17 |
Half a Bubble Off Plumb
Drives: 2009 Yaris Sedan Join Date: Mar 2009
Same here. I think it holds about 10.2 gallons shortly after that comes on.
#18 |
Pretty green Yaris Verso
Drives: Toyota Yaris Verso Join Date: Mar 2009
My 2000 (100000 mile) Yaris Verso goes from 2 bars to blinking one. First time I had it down low, it did 90 miles without running out from when the single flashing bar came on. But I have run out (embarrassingly) with only 50-60 miles from that point, and that with a normal mpg of 44. I don't think the bars in the fuel indicator behave at all consistently.
| DIY - rear sway bar [pics] | cali yaris | DIY / Maintenance / Service | 199 | 07-28-2022 05:25 AM |
| DIY: Strut Tower Brace Bar | redyaris | DIY / Maintenance / Service | 18 | 03-16-2014 06:52 PM |
| Rear Sway Bar Instructions - Additional Pics | SeaYa | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 02-26-2009 01:05 PM |
| solid torsion bar bushings... the best rear anti roll upgrade | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-05-2008 11:37 PM |
| c one motorsport performance bars | badhabitz | Performance Modifications | 17 | 08-23-2006 10:31 PM |
