Old 07-27-2009, 10:50 AM   #1
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
I've had that problem. I generally chalk it up to pad fade. It's not fluid fade. The pedal goes mushy when your fluid boils. What you're describing (and what I sometimes feel) is that you're giving the pedal a good firm push... the pads just aren't biting. Pad fade.
It just happens so rarely for me that I haven't bothered to change out my pads yet!
Old 07-27-2009, 09:56 PM   #2
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
I could understand pad fade if I was driving and braking hard. This was inching around the parking lot of a Walmart looking for a parking space.
I wait 10 seconds, pump the brake pedal and then it depresses and I feel the brake pads bite like normal. It's almost like something is getting under the pedal and I just can't push it hard enough to slow down.
I'm not too cool about this because it could happen at a bad time.
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Hard clutch pedal ? hystria General Yaris / Vitz Discussion 5 05-11-2007 06:12 AM
