Old 07-30-2009, 09:02 AM   #1
That fan motor will work on a Yaris LB or Sedan from 06 through 09. You really can't tell if a motor is good by looking at it. Applying power to it and watching it spin / listening for bushing/bearing noises is the easiest way to tell if its OK.
By the way, the fuse for the cooling fan is not Fan No. 2, it is RDI. Fan No. 2 is one of the two relays in the fan control circuit.
Check RDI, which is a 30A fuse in the under hood fuse panel on the driver's side (it is one of the big guys in the strip between the connectors and the small blade fuses.
Old 08-17-2009, 04:02 PM   #2
yarisitis
yarisitis's Avatar
Drives: 2008 Yaris LB
I was finally able to check that 30A RDI fuse today since I've been out of town for awhile.
And you were right, the fuse was burned!
So where can I get a replacement fuse? Can I get one of these at an auto parts store like Auto Zone or will I have to get one at the dealer?
yarisitis is offline   Reply With Quote
Old 08-17-2009, 04:23 PM   #3
Marthos
Marthos's Avatar
Drives: 07 3Dr LB
An auto parts store will almost always be cheaper if they have the part, call one up and ask!
You mentioned salvaged, was it hit?
That fuse blew for a reason, you maynot be done after replacing it.
Marthos is offline   Reply With Quote
Cold air intake vs air intake Liu997 Performance Modifications 15 11-05-2009 05:32 PM
Simota Carbon Charger Cold Air Intake lilredrocket Performance Modifications 18 04-13-2009 03:16 AM
