Originally Posted by Luna V 2.0
Ok, my tires seems to be fine, I haven't checked the weight of the tires as someone mentioned they might be different from the ones I had before. Is that information right on the tires? I can't seem to find it.
I've been driving without the AC recently just to see what happens, its still too soon to see because I recently filled up. I calculate my MPG when I do fill ups, how many miles I got divided by how much I put in to fill up (how much I used)
So far I think I'll have someone check the air filter and the injectors as some of you suggested, the main problem is I know nothing about cars so I have to trust others to do the work correctly. Eek. I'll see if theres some improvement soon.
unless you have over 30,000 miles i wouldn't even worry about checking the injectors... realistically... anything less than 50,000 and they should be fine unless you only put the off brand gas in your tank. Just check the air filter... if its nasty, spend the $15 and put in a new one.
