Old 08-01-2009, 11:05 PM   #1
Tach wire location at pin 9 of DLC3 connector:
09 (Beige wire):
07-08 (Green Wire):
Old 09-07-2011, 08:58 PM   #2
cgarcia1821
Drives: 2011 5-door Toyota Hatchback
Exclamation HELP!
09 (Beige wire):
07-08 (Green Wire):
I accidentally starting messing with these wireds to see if any were for the headlights (i was trying to install interior led lights) and all of my dashboard lights are now going off like crazy (airbag, check engine, battery, sliding, etc), the a/c and heater doesn't work, the turns signals don't work if i step on the brake, and it no longer indicates what gear i'm in. I really messed up, but I would like to know if anyone has had this issue or knows a solution or what's going on.
cgarcia1821 is offline   Reply With Quote
Old 09-07-2011, 10:05 PM   #3
YIKES!!!!
Check the Dome and ETCS fuses in the under hood fuse panel. Hopefully you popped one of those and didn't cook the ECM. The DLC3 connector is purely for diagnostics. There is a constant power wire on the connector for powering a diagnostic tool, but other than that no pin on that connector should ever be connected to a load.
Old 11-03-2011, 04:59 AM   #4
syedgakbar
Drives: Toyota Vitz
Vitz DVD Player LCD Panel Lights
Hi,
I recently purchased the Vitz 2007 model. It has DVD and CD Player which works great. The problem is that this device panel lights don't glow even when I turn the parking lights on. Here is how my car DVD panel looks like:
http://assets.pakwheels.com/2011/car...009-655872.JPG
I had the car checked by local Car Audio Workshop and they technician guy looked at the wiring and said that these are okay. What else could be the problem?
Regards, Akbar
syedgakbar is offline   Reply With Quote
Old 08-28-2012, 10:46 PM   #5
mamun22s
Drives: Toyota Vitz
09 (Beige wire):
07-08 (Green Wire):
Can any one help the abt the chip on the pic coloured red and blue. what is there function?Be cause one of them getting hot. What actually they do? and also the function of the fuse? How do i know whether they functioning or not.
mamun22s is offline   Reply With Quote
Old 08-28-2012, 10:56 PM   #6
They are relays. The left one is the IG1 relay and the right one is the HTR relay. The left one gets warm when the ignition is on and the right gets warm when the blower is running. That is normal.
The fuse above it to the left is for the power windows and the one above it to the right is for the defogger.
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 04:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 03:32 PM
