Old 08-04-2009, 08:09 AM   #1
MGargano
Drives: 2009 Yaris Hatchback
Since you won't be transferring the side airbags to the new seats, you'll need to install a 3 ohm resistor across the connector (in place of the airbag) to keep the system happy.
I haven't really looked at any of the wiring to see what's involved, so I'm not sure which connector you mean. Are there any other surprises I can expect with this swap?
Old 08-04-2009, 08:28 AM   #2
It's a two pin yellow connector (under the seat) for the side airbag squib. The 3 ohm resistor trick is the same thing that is done to eliminate the steering wheel airbag, when swapping steering wheels. It fools the SRS into thinking that the airbag is still present.
I am sure there will be a few surprises, but I don't think that you'll run into anything insurmountable.
Old 08-04-2009, 08:35 AM   #3
MGargano
So it's as straight-forward as it sounds? Just plug the resistor into the two pins in the connector and voila?
Old 08-04-2009, 08:41 AM   #4
Yes - Plug it in, and tape or heat shrink it.
Old 08-04-2009, 06:41 PM   #5
MGargano
Ok so of course my local Radio Shack doesn't have 3 ohm resistors. Will a 3.3k ohm resistor work? Are they they same? Some had a 'k' and some had an 'm' and some just said 'ohms'
Old 08-04-2009, 07:57 PM   #6
You want just ohms (k=1000's, M=millions). 3.3 ohms would be fine, but not 3.3 K or 3.3 M. The resistors should be 1/2 watt rated ones as well (they come in 1/8, 1/4, 1/2, etc).
Old 08-04-2009, 11:30 PM   #7
MGargano
If their website is any indicator, it looks like Radio Shack doesn't carry these at all. Looks like I've got some hunting to do, unless I want to order them online and pay $hipping. Thanks for the info though!
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
FS: Recaro Pole Position Racing Seats (black) -- socal 03Z33 Items for Sale by private party 13 12-07-2008 05:08 PM
sparco seats and pedals (pics) turboyaris Cosmetic Modifications (Exterior/Interior) 18 09-05-2007 02:43 AM
Sport / Racing seats worth the while? mikeukrainetz Cosmetic Modifications (Exterior/Interior) 10 11-19-2006 01:17 PM
Yaris Liftback Seats artyin General Yaris / Vitz Discussion 3 04-30-2006 04:07 PM
