Installer
Drives: 2008 Yaris HB Join Date: Nov 2008
Sounds like you are using the power antenna turn on (blue wire) to turn on the amps instead of the amp turn on wire(blue with white stripe). When you switch sources from tuner the blue wire stops supplying 12v while the amp turn on wire supplies 12v all the time.
Audio Junky
that sounds right....... forgot about power antenna wires (never have had to use one).
| 5w20, My .02 | Turbo&Auto | DIY / Maintenance / Service | 23 | 07-15-2007 06:31 PM |
