Old 08-05-2009, 02:59 PM   #7
Mobius1
Installer
Mobius1's Avatar
Drives: 2008 Yaris HB
Sounds like you are using the power antenna turn on (blue wire) to turn on the amps instead of the amp turn on wire(blue with white stripe). When you switch sources from tuner the blue wire stops supplying 12v while the amp turn on wire supplies 12v all the time.
Mobius1 is offline   Reply With Quote
5w20, My .02 Turbo&Auto DIY / Maintenance / Service 23 07-15-2007 06:31 PM
