Old 08-08-2009, 04:05 AM   #1
I think only the ends show. The bar itself is tucked up under the axle pretty well. The bar "faces" front so it's not like it's directly under the bumper. and, I suppose you could spray any "offending" white bits that you could see from behind after you installed it, as well.
Thanks for the kind words too.
Old 08-08-2009, 06:59 AM   #2
2+2
Drives: 09 3Dr Manual
Ahhh. It faces front. It's a non issue then. Thanks.
Just put the pedal down and let the devil take the hindquarters.
2+2 is offline   Reply With Quote
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
Rockland Toyota/Scion Car show Zefoxe NY / NJ/ CT / PA 47 05-26-2009 08:16 PM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
