Old 08-10-2009, 06:10 PM   #1
MGargano
Drives: 2009 Yaris Hatchback
The people who swapped the clusters hot, saw the clusters' mileage remain. The one person who was told to disconnect the battery by the junk yard dudes saw the cluster mileage change to his correct mileage on power-up.
At this point, I'd like to see a second person disconnect the battery before performing the swap to see what the result is.
Think there's a way to back-track this? I didn't think to disconnect the battery when I swapped my '09 cluster for the '09 "S" cluster and now I'm kicking myself.
MGargano is offline   Reply With Quote
Old 08-10-2009, 08:37 PM   #2
Well you've definitely disconnected the battery since the swap with all of the seat troubleshooting, so it definitely looks like after the fact doesn't work for that theory.
At this point, other than the Techstream tool method, the only DIY method that might work is the core swap that I mentioned above. Before anyone actually tests that theory snap a pair of pics of the core (front and back) like the ones below, so I can look for any differences that may cause bad things to happen.
Installing Speedhut tach, need help! RedRide DIY / Maintenance / Service 2 07-05-2009 04:02 PM
Canada tach in a US Yaris LB tiksman DIY / Maintenance / Service 49 02-27-2007 02:40 AM
