Old 07-05-2009, 01:07 PM   #1
RedRide
RedRide's Avatar
Installing Speedhut tach, need help!
I attempted to install a speedhut Revolution tach in my '09 HB.
However, I'm not quite shure if this tach can get an RPM signal from the OBD port. I conected the RPM lead i to blue/green wire but there is no aparent RPM signal to the tach.
Everthing else seems to be working properly including setting the pulses per RPM.
Does this tach need to be connected directly to a coill pack,yelow primary wire as per the speedhut instuctions? if so where is the best place to go through the fire wall.
EDIT:
Problem solved via this thread:
http://www.yarisworld.com/forums/sho...=wire+firewall
It appears that the OBD port tach signal wire is not blue/green on the '09s but light brown.
The tach is now working properly.
Old 07-05-2009, 03:22 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
searching FTW!
Old 07-05-2009, 04:02 PM   #3
RedRide
RedRide's Avatar
searching FTW!
Yeah, I was actually searching for a way to get a wire through the fire wall when I (accidenty) discoverd the OBD port soulution for the '09s
Tach Installed & Temp Wheels On justjesus Off-topic / Other Cars / Everything else Discussions 4 02-07-2009 01:26 AM
Installed Tach...Tach works, RADIO doesn't! 5spBlazer DIY / Maintenance / Service 17 08-06-2007 08:57 PM
How to install tach? charles nelson DIY / Maintenance / Service 1 08-04-2007 11:34 AM
US Yaris: Adding a tach? Thirty-Nine General Yaris / Vitz Discussion 159 04-05-2007 08:23 AM
Auto-Meter Silver Sport Comp Mini Tach ChinoCharles In Car Entertainment + Electronics (audio / video / alarm) 7 02-26-2007 05:14 PM
