Old 08-04-2007, 07:28 AM   #1
charles nelson
Drives: red Liftback
Cool How to install tach?
Is there a simple way to install a tach in a 2007 Liftback?
I just installed a tach in my Ford E450 SuperDuty..Ford provided
a single labeled Tach connection wire adjacent to my wiper motor
under the hood. It took about 20 minutes to complete...mainly just
running the connection wire through the firewall and connecting
power wires to the fuse box. (Sweet)...
I have looked under the hood of my new liftback and all I see are
harnesses...do I have to 'cut' into the harnesses?!?
Does the liftback have the same wiring harness as the Sedan?...I assume
that all sedan harnesses must have a tach wire for the tach 'option'...so
if the harnesses are the same...there should be a deadend connector
somewhere under the liftback hood, right?
charles nelson is offline   Reply With Quote
Old 08-04-2007, 11:34 AM   #2
cm07yaris
Drives: 2007 Toyota Yaris Blazing Blue
Send a message via AIM to cm07yaris
If you would have scrolled down a little bit... http://www.yarisworld.com/forums/showthread.php?t=662
cm07yaris is offline   Reply With Quote
Installed Tach...Tach works, RADIO doesn't! 5spBlazer DIY / Maintenance / Service 17 08-06-2007 08:57 PM
RPM Gauge Install rwseattle DIY / Maintenance / Service 1 04-15-2007 12:23 PM
Auto-Meter Silver Sport Comp Mini Tach ChinoCharles In Car Entertainment + Electronics (audio / video / alarm) 7 02-26-2007 05:14 PM
tach gauges install dansides General Yaris / Vitz Discussion 0 02-01-2007 11:31 PM
Liftback - Easiest Way to Get a Tach and Cruise Control... weeze-dog General Yaris / Vitz Discussion 60 10-20-2006 05:40 PM
