Cousin Vitz
Drives: Yaris RS 5DR / Vitz RS wannabe Join Date: Mar 2006
194 Parking Light Harness / Socket
It appears one of my parking light no longer works.
I tried different wedge bulbs, but it will not turn on. I checked the fuses in the engine bay, and the main 10A fuses for each headlight housing was good. Is there a specific fuse for the parking lights? I don't think there is, but if anyone can correct me I would appreciate it. I'm not sure if the socket itself is the issue, or if the wiring is damaged. My car was in an accident and after the shop released it, all the lights in each housing worked except for the one parking light (driver side). I would bring it back to them to look at, but I'm pretty tight for time lately. Anyone know where to get a replacement Parking Light 194 harness / socket for the stock headlights? I'm wondering if I should run wires to the side that works and tap the power/ground wires for that side's parking light...
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930 |
The parking lights run off of the TAIL fuse (in the under the dash fuse panel).
They pass through connector D13 in the under hood fuse panel. In the picture below that is the connector on the left. The rightmost wire on the bottom row goes to the right side parking light and the next one over to the left goes to the left one. With power off you could measure continuity between the second one and your driver side tail socket. If it is open, then you know that that wire is damaged. In that case you could snip it one either end (leaving a few inches to work with) and splice a new piece in between. |
No pic...
Cousin Vitz
Thanks CTScott.
I will take a look later to see if the wire is damaged or not.
#6 | |
Cousin Vitz
Great reference. When you say right side parking light, you mean the driver side? Right side = facing the vehicle head on, so the driver side (in North America)
Slowy getting there
Think of it how you drive the car US drivers sit on the Left hand side.
^ exactly. I referenced the picture from the way it is shown, but the wire end points are referenced to the car itself (as if you were standing behind it).
![]() ![]() ![]() ![]() ![]() Drives: 2007 Bayou Blue!!!!!!! Join Date: Nov 2006
CT you are an electric guru!!!
#10 | |
Cousin Vitz
The D13 connector is the LEFT connector in your picture, correct? I followed the power wires for both parking lights and they are the same shield as the two bottom right green wires on the left connector.
Cousin Vitz
Thanks to CTScott for the reference on the power source at the fuse box.
It turns out the wiring was damaged about a foot away from the light socket. The wire came clean out like it was cut! I patched it up and it works fine now. Didn't have to mess with the fuse box or any of the wiring closer to the fuse box.
| Installing Trailer Light Harness | vandallen | DIY / Maintenance / Service | 7 | 06-10-2024 10:06 AM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| Parking Light replacement | Doug007 | DIY / Maintenance / Service | 1 | 11-06-2008 06:28 PM |
| Using parking light as DRL? | GabL | DIY / Maintenance / Service | 6 | 11-11-2006 09:31 AM |
