Old 08-11-2009, 09:39 PM   #2
The parking lights run off of the TAIL fuse (in the under the dash fuse panel).
They pass through connector D13 in the under hood fuse panel. In the picture below that is the connector on the left. The rightmost wire on the bottom row goes to the right side parking light and the next one over to the left goes to the left one. With power off you could measure continuity between the second one and your driver side tail socket. If it is open, then you know that that wire is damaged. In that case you could snip it one either end (leaving a few inches to work with) and splice a new piece in between.
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
Parking Light replacement Doug007 DIY / Maintenance / Service 1 11-06-2008 06:28 PM
Using parking light as DRL? GabL DIY / Maintenance / Service 6 11-11-2006 09:31 AM
