What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
I'm looking to add a few lights under the dashboard that are on the same circuit as the dome light (so they turn on when the door opens) and was wondering which wires they are. I have the 09 sedan, does anyone know which wires I could use?
#2 | |
The connector (4K) on the upper left in this picture, is the feed to the map and dome lights. White with a black stripe ground, Pink is the "door open" switched ground, and blue is 12V fed from the DOME fuse. |
#3 | |
![]() ![]() Drives: Yaris RUSH HatchBack Join Date: Jan 2009
hi there, may i know where can i find this stuff? regards, Charles |
#5 | |
so did ya mean it is located under the driver seat or passenger seat? because my driver seat is on right hand side. regards, Charles. |
#7 | |
Hihi, I already tested the wires tat u mentioned in the picture.. The blue wire does give constant 12v and the pink wire should turn on the lights with the door right? I already tested the pink wire by multimeter and it will only give 12v when the door is closed. So may I know what can I do in order to get 12v out when the door is open because I want my led to be on only when the door is open... Thanks... Last edited by charleschia1986; 11-24-2009 at 01:53 AM. |
#8 | |
thanks a lot...
i tried and it WORKS..... thank scott |
#10 | |
Hi to all... just a noob here in M.E., just wondering if I tap the leads (+,-) of an LED light to the pink n blue from that pic above, will the new led light acts the same as the dome light? will the new led light dim to off as well upon turning off the ignition? Or just turns on when the doors were open? Sorry to much question. Need help where I can tap my led lights so that it behaves the same like the dome light, using its switch also to turn on my led lights underneath. Thanks so much. -jon
#11 | |
#12 | |
![]() Drives: Vios E Join Date: Mar 2011
Hi, how do you suggest wiring LEDs so that they behave exactly like the dome light does? ie. turn on when doors open, switch to ON - light up with dome light. thanks
The only way to make them function exactly the same as the dome, including the switched on mode is to run the power wire up through the headliner to the dome light and make your connection there.
#15 | |
Now I'm worried they might catch fire/melt/burn. What's your opinion on this? Should I get thicker gauge wires and redo the whole thing? Last edited by iicaie; 03-23-2011 at 11:41 AM. |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 03:55 AM |
| New Yaris race car | Jason@SportsCar | Tracking, Racing, Auto-X Forum | 83 | 11-01-2012 02:32 PM |
