Old 08-17-2009, 08:53 PM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
2009 vitz: it is normal.
although, your eyes might be off, because 100kmh in 4th is 3000rpm and 5th is about 2700rpm.
plug in the gear ratio, for the 1nz-fe 5spd yaris.
First Gear Ratio (:1)
3.55
Second Gear Ratio (:1)
1.90
Third Gear Ratio (:1)
1.31
Fourth Gear Ratio (:1)
0.97
Fifth Gear Ratio (:1)
0.82
Reverse Ratio (:1)
3.25
Final Drive Axle Ratio (:1)
3.72
edit: this sheet is pretty much all good, except the final gear ratio, just modify as needed.
Gargling noise when RPM drops... ammophobia DIY / Maintenance / Service 8 09-28-2009 08:43 AM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 12:41 AM
Best MOD for midrange to lower rpm gain. Neen a little more low end grunt. dtbrown Performance Modifications 13 03-29-2009 04:35 PM
Optimal RPM for shifting Gears ? JapRulezz Performance Modifications 8 03-07-2009 04:16 AM
RPM problem. rwseattle Performance Modifications 7 04-03-2007 11:09 AM
