Old 08-26-2009, 03:25 PM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by SweetRS View Post
what do the shims from penguin garage look like??
http://www.yarisworld.com/forums/showthread.php?t=19450
Old 08-26-2009, 03:42 PM   #2
SweetRS
Drives: 2006 Yaris Rs
Thanks!! couldnt i just put washers behind the hub?? instead of buying the spacer if i only want to change the camber and not space it?
nevermind, just read it all...Thanks man...why wouldnt more ppl be using washers to fix there camber though??
SweetRS is offline   Reply With Quote
Old 08-26-2009, 02:56 PM   #3
MUSKOKA800
MUSKOKA800's Avatar
Have you checked with an alignment shop to see what they'd us to correct extreme positive camber situations (colision repair etc)?
When I had a 4 wheel alignment done the alignment rack did measure those spec's. the tech said the toe was slightly out at one of my rear wheels but not enough to be concerned. He said if I noticed odd tire wear to come in and they'd address it. With shims behind the brakes I assume.
Old 08-26-2009, 03:00 PM   #4
SweetRS
yah i work at a Toyota owned collision repair shop, so, i had an alignment done when i put the springs on...toe was in ever so slightly...
so, what do the shims for the spacer look like??
installing Penguin Garage rear hub spacers! Tamago DIY / Maintenance / Service 101 05-21-2011 12:29 PM
Adjusting rear camber?? PHXDEMON Wheels, Tires and Suspension Forum sponsored by The Tire Rack 63 10-23-2009 12:11 PM
New Product: Penguin Garage Rear Camber Shims! Penguin Garage Penguin Garage 11 10-22-2009 10:20 PM
Penguin Garage Rear Hub Spacers!! Penguin Garage Sponsors Classifieds Area 92 09-02-2009 06:16 PM
Penguin Garage Rear Hub Spacer Raffle!! Penguin Garage General Yaris / Vitz Discussion 27 06-30-2009 01:05 AM
