Old 08-26-2009, 01:36 PM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by SweetRS View Post
how do i get the most negative camber in the rear? if i decide to stuff wider wheel/tire (15X8, 195/45/15) back there and have it fit...with rolling the fender ofcoarse
if you want more than an extra 1-2 degrees rear camber, you'll want to look into custom shims. Penguin Garage toyed with the idea as well as the Kiwi, but no one bit. no point in spending hundreds on R&D to sell one measly set of camber shims.
you could always stack the shims from penguingarage ;) put two under each lower bolt each side, get an extra 2deg camber. not recommended, but iv'e seen it done on the honda fit with no ill effects.
Old 08-26-2009, 01:51 PM   #2
SweetRS
Drives: 2006 Yaris Rs
Hmmm, interesting! hey if hondas can do it so can we...im just curious though, would i need longer bolts for that kinda operation?and if there is a slight angle of the hub are the bolt still gonna fit properly? maybe i don treally understand how these work
SweetRS is offline   Reply With Quote
installing Penguin Garage rear hub spacers! Tamago DIY / Maintenance / Service 101 05-21-2011 12:29 PM
Adjusting rear camber?? PHXDEMON Wheels, Tires and Suspension Forum sponsored by The Tire Rack 63 10-23-2009 12:11 PM
New Product: Penguin Garage Rear Camber Shims! Penguin Garage Penguin Garage 11 10-22-2009 10:20 PM
Penguin Garage Rear Hub Spacers!! Penguin Garage Sponsors Classifieds Area 92 09-02-2009 06:16 PM
Penguin Garage Rear Hub Spacer Raffle!! Penguin Garage General Yaris / Vitz Discussion 27 06-30-2009 01:05 AM
