Old 08-29-2009, 02:53 AM   #1
The smoke tells you nothing about how much carbon was built up in your engine or was removed by the Seafoam. The smoke is mostly coming from the light oil in the Seafoam, called "pale oil" in the MSDS. True, if the gummy stuff that builds up on intake valves and ports, or the harder stuff that builds up in combustion chambers, gets broken off and moved to the exhaust, it'll get hot enough to put out smokey gases. But you can't tell how much of it's from that stuff as the oil you're pouring into the intake smokes out. Do the procedure over and over and you'll always see lots of smoke. (I wouldn't recommend repeating it frequently as I think it is somewhat hard on catalysts and O2 sensors.)
Originally Posted by RedRide View Post
Although I use seafoam I have to agree. People see the smoke when sucking Seafaom though the intake/vacumn lines etc and think they are cleaning out dirt.
Personally, I just dump a can of Seafoam in the gas tank ocasionally. This gives the most benefits.
hmm, didn't know that, but why did my car not smoke as bad as I see on YouTube? In anycase, easy maintenance that I can do every other oil change (so every two years).
Old 08-29-2009, 06:54 AM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Perhaps your catalyst was warm enough to be active and afterburned the oil more efficiently than some that have been posted. My '98 Mercury Villager smoked modestly as well. It had 117,000 miles on it, BTW, and was starting to make a cold engine knocking that I suspected was "carbon knock." That engine had reason for suspicion of a good bit of buildup after that long a life of mostly in-town driving, and ran better after treatment.
L.E.D not lasting as expected?? marcus Cosmetic Modifications (Exterior/Interior) 9 03-31-2009 11:10 AM
You'd never expect to see this... SilverBack Off-topic / Other Cars / Everything else Discussions 5 03-05-2009 12:15 AM
expected life uncleyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 09-04-2007 09:01 PM
Unexpected n expected visit to sam07yaris Blenjar Photo-Video-Media Gallery 10 08-13-2007 02:39 PM
Yaris..Better than I expected....!!! drdavidr4u New YARIS Purchase Forum 5 11-28-2006 07:50 PM
