Old 03-30-2009, 05:59 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
L.E.D not lasting as expected??
l.e.d's not lasting as long as advertise..in a real sense it should last longer than regular auto bulbs BUT,,..assuming that the right current is going thru the led.. they maybe able to regulate the voltage but amperage is the same and the amps is what shortening the life of the led..which now last far shorter that the standard bulb..does this make sense???
Old 03-30-2009, 06:12 PM   #2
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
The LED's will take the amount of current they're spec'd to take. The LED's typically die due to the voltage spikes in the electrical system. I have yet to see any LED drop-in bulb kits offering more than just a simple resistor and diode regulation. I go overkill on my stuff and use a voltage regulator with caps at the input voltage and regulated voltage sides.
taKuto is offline   Reply With Quote
Old 03-30-2009, 06:30 PM   #3
marcus
toyota
marcus's Avatar
im afraid to put them led strips i bought not knowing if itll last that long..
Old 03-30-2009, 08:15 PM   #4
shameer_k
Drives: yaris sedan
i put those strips in my headlight....dey last about a month before they started flickering then they just died.
shameer_k is offline   Reply With Quote
Old 03-30-2009, 09:05 PM   #5
+1 on the voltage regulator.
A $0.50 LM7812 (12VDC regulator), a .33uF cap on the input and a .1uF cap on the output and the LEDs will outlast the car.
Old 03-30-2009, 10:19 PM   #6
marcus
toyota
marcus's Avatar
i have LED strips from Oznium and these are weatherproof and work great. dont forget that if water gets on the LED it will short it, LED are extremely sensitive to reverse voltage and will burn up. typically for a 12V dc automotive voltage a 1.2kOhm resistor will give you 10mA of current which is well within the modern LED current. Most of the hyper bright LEDs will go as high as 40mA but all you really need is 10mA. as taKuto said a voltage regulator will help a lot, but what i do i tap into a light harness which prevents spikes from damaging the leds. all my leds are on the main headlight switch
how have you had ur leds...
Old 03-30-2009, 11:45 PM   #7
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
?, where do we install them? I got V-leds al over my HB and i don't want them to die on me! It's been a month and still no issues but I'd like to protect them.
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 03-31-2009, 12:30 AM   #8
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
depends how you do it, but most likely you'd need to splice your wires since you arent working with a custom LED board. You could try to just put a 1n4001 diode in series and a capacitor in parallel for a small improvement on reliability, and it should be easier to wire up.
Old 03-31-2009, 10:59 AM   #9
marcus
toyota
marcus's Avatar
my led turn signals is tapped on the turn lights so far it works great but its only been 2 weeks..heres the link.. just wait a bit the video is meant for front bumper paint job.
http://www.youtube.com/watch?v=2GSCc.../hqdefault.jpg
Old 03-31-2009, 11:10 AM   #10
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
im curious as to the LED strips and water. BOBSELECTRIC has them mounted in his lower bumper where their exposed to the elements.....
You'd never expect to see this... SilverBack Off-topic / Other Cars / Everything else Discussions 5 03-05-2009 12:15 AM
expected life uncleyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 09-04-2007 09:01 PM
Unexpected n expected visit to sam07yaris Blenjar Photo-Video-Media Gallery 10 08-13-2007 02:39 PM
Yaris..Better than I expected....!!! drdavidr4u New YARIS Purchase Forum 5 11-28-2006 07:50 PM
