Old 08-31-2009, 05:29 PM   #1
GMKing
Drives: 2007 toyota Yaris sedan
After reading this whole thread I'm still left confused.
from factory ALL manufacturers have a very tiny amount of oil fed to the intake system.
and you guys are trying to collect it before it gets there?
I understand the idea of preventing extra oil from burning in your combustion process, and keeping this extra oil off of your valves, particularly if it's about time to change your oil and it's got an amount of junk in it that you'd prefer not to get into your intake or on your valves.
but has anyone honestly considered WHY the manufacturer's ALL do this? they want your engine to be reliable (nearly) as much as you do, as well as FE. They must have some reason for creating this line and doing this. The only reasons I can think of is the air intake is metal right? metal corrodes. Corrosion prevents airflow, and airflow over corrosion passes right into your engine. now your engine is steadily eating rust (or oxidation, which the engine would eat to a much lessor degree).
also I can imagine that this oil many of you are deciding to prevent from going into your engine is lubricating your valve and valve seats, so that they create a decent seal when closed and last longer then bare metal hitting metal. It's very possible I'm wrong, and I'd love to believe that this awesomely cheap mod is good for my engine and it's longevity, however I cannot do so without having the above statements properly debunked.
GMKing is offline   Reply With Quote
Old 11-22-2010, 09:02 PM   #2
Judas Iscariot
Drives: 2008 Yaris HB
+1
bumpity
Judas Iscariot is offline   Reply With Quote
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Synthetic Oil Kaotic Lazagna DIY / Maintenance / Service 122 09-20-2007 03:40 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 02:56 AM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 08:37 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
