Old 06-19-2009, 01:26 PM   #19
Brad D
Drives: 07 Yaris RS 3dr
Originally Posted by NonStopTuning View Post
While it is true that all CNC machined pieces SHOULD be the same, they often are not.
Certain machines, as well as certain companies, have better/tighter quality/tolerance controls than others.
Ture but this is not aerospace, a crappy HAAS could poop these things out all day long just fine.. the aluminum would be a walk in tha park for a weaker machine.
Well my GF took the car today (5'10" and 120lbs.. arms like sticks) and she said she likes it better this way.. I guess im just being picky.. I would of thought I would of got a call "some things wrong with the car.."
im still going to see about moving the cable up.. so its not such a bind for it going upward
Brad D is offline   Reply With Quote
Old 06-19-2009, 04:32 PM   #20
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Do the WD-40....
As I said before... After I installed the metal bushings I had this same problem with the SSk.
It took some level of effort to move the level into gear. Mostly on the upper gears... 1st/3rd/5th
Due to the angle there was some friction beteween the SSk and the cable..
A bit of wd-40 solved the problem inmediatly... Now the shifts go in as they had butter on.... SMOOTH!
Make sure you spray all the moving parts on the cables/ssk/bushings assembly.
It should take you 1 minute.
Old 06-19-2009, 08:16 PM   #21
Brad D
yeah i guess i should try some WD-40 before I mod the bracket...
Old 06-20-2009, 12:03 PM   #22
MGargano
Drives: 2009 Yaris Hatchback
I have the NST SSK1 (engine bay) & TWM Short Shifter and am having a similar toughness in pulling/pushing in and out of gear. Is there any way to get this 'adapter plate' that comes with the TRD? Does anyone have a pic of it and/or know where it mounts?
MGargano is offline   Reply With Quote
Old 06-21-2009, 05:11 AM   #23
CASTREX
CASTREX's Avatar
The toughness in your case will come from the TWM mostly.... and no fix for that.
Try the lubricant and see if that helps...
No way to get that plate other than buying a TRD SSK.
NST SSK + TWM is hardcore....
Old 06-21-2009, 11:08 AM   #24
MGargano
I sprayed everything with WD40 yesterday and the shifting is 100% smoother. No more fighting to pull it out of gear, so I guess it's all good now.
Old 06-21-2009, 03:07 PM   #25
where did you spray exactly? - I'm sure others would benefit from what you did.
Old 06-21-2009, 07:05 PM   #26
llimonce
Drives: yaris sedan
i installed the nst ssk yesterday without problems .. i love it !!!
llimonce is offline   Reply With Quote
Old 06-22-2009, 12:39 AM   #27
MGargano
I'm not too familiar with the technical names for the different parts, but I basically tried to spray all the moving parts connecting the shifter linkage to the transmission, so I hit the NST SSK (above and below, where the linkage bushing is), the other 'arm' that takes the second NST linkage bushing, and the joints connecting both of these 'arms' to the side of the transmission.
Again, I'm sure I did a shit job explaining, but the best way to do it is to have someone sit in the car and work the shifter through all the gears. While they're doing that, spray everything you see moving and you'll end up with a short, firm shift that's MUCH more fluid moving through the gears, rather than fighting with each one like I was before.
Old 06-22-2009, 01:33 AM   #28
CASTREX
CASTREX's Avatar
I did the same.
I do believe however that the changed angle of the shifter cable add some friction between the ssk pin and the bushing... The pin should rotate freely inside the bushing... the lubricant should help on this task.
The feeling is 100% better and I would recomend this to al the people using the ssk.
When I first install it I just thought that was the way it was... and it didn't felt bad... just a little tough...
In my case the toughnes started after I installed the cable metal bushings
Old 06-22-2009, 03:14 AM   #29
MGargano
I agree... I thought the toughness/tightness was the way it was supposed to feel after the SSK. The WD40 made a huge difference.
Old 08-31-2009, 06:08 PM   #30
posaunemeister
Drives: 2008 Yaris S LB - MM
I just purchased a Piggies a few minutes ago. I can't wait to see the results once I get it installed. Mind you, I've only been driving a manual for exactly two weeks, but by now I am good enough to notice a difference. :)
Can anyone tell me who's selling an NST 10% underdrive pulley for the cheapest price (including shipping)? Thanks in advance.
posaunemeister is offline   Reply With Quote
Old 08-31-2009, 06:33 PM   #31
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
You can get the from Cali_Yaris" aka Garm aka Yaris God @ www.microimageonline.com
Old 08-31-2009, 07:04 PM   #32
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
just a warning, WD-40 eats at plastics, now i dont know what exactly is plastic or close enough to it that wd-40 would eat it, but i dont want to spray anything without knowing for sure.
Check out my Build thread:
Old 08-31-2009, 10:58 PM   #33
XYaris
Drives: '09 Yaris LB
Yea. To further the wd40 concerns.
Wd40 is a degreaser. In my experience as a bike mechanic, folks will spray this stuff on moving parts and are generally releived at the results. I'm not saying it doesn't work (although it may be short lived) but an actual lubricant may be better and less harmful to rubber/plastic bits.
Just a thought.
XYaris is offline   Reply With Quote
Old 09-01-2009, 01:44 AM   #34
posaunemeister
Will vegetable oil work? I suppose so.
DIY: Make Your Own Short Shifter 33OH Cosmetic Modifications (Exterior/Interior) 7 02-24-2009 02:06 PM
twm short shifter installed! dngz Performance Modifications 115 08-02-2007 02:11 PM
TWM Short Shifter Boxing Week Blowout! TWM Performance Sponsors Classifieds Area 2 01-08-2007 05:01 PM
November: Big Yaris Short Shifter Sale! TWM Performance Sponsors Classifieds Area 14 12-12-2006 11:50 AM
TWM Yaris Short Shifter Sale! TWM Performance Sponsors Classifieds Area 9 08-28-2006 04:37 PM
