#19 | |
![]() Drives: 07 Yaris RS 3dr Join Date: May 2009
Well my GF took the car today (5'10" and 120lbs.. arms like sticks) and she said she likes it better this way.. I guess im just being picky.. I would of thought I would of got a call "some things wrong with the car.." im still going to see about moving the cable up.. so its not such a bind for it going upward |
#20 |
Who said Yaris was slow?
Do the WD-40....
As I said before... After I installed the metal bushings I had this same problem with the SSk. It took some level of effort to move the level into gear. Mostly on the upper gears... 1st/3rd/5th Due to the angle there was some friction beteween the SSk and the cable.. A bit of wd-40 solved the problem inmediatly... Now the shifts go in as they had butter on.... SMOOTH! Make sure you spray all the moving parts on the cables/ssk/bushings assembly. It should take you 1 minute. |
#21 |
yeah i guess i should try some WD-40 before I mod the bracket...
#22 |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
I have the NST SSK1 (engine bay) & TWM Short Shifter and am having a similar toughness in pulling/pushing in and out of gear. Is there any way to get this 'adapter plate' that comes with the TRD? Does anyone have a pic of it and/or know where it mounts?
#23 | |
Try the lubricant and see if that helps... No way to get that plate other than buying a TRD SSK. NST SSK + TWM is hardcore....
#24 |
I sprayed everything with WD40 yesterday and the shifting is 100% smoother. No more fighting to pull it out of gear, so I guess it's all good now.
#25 |
where did you spray exactly? - I'm sure others would benefit from what you did.
#26 |
![]() ![]() Drives: yaris sedan Join Date: Oct 2008
i installed the nst ssk yesterday without problems .. i love it !!!
#27 | |
Again, I'm sure I did a shit job explaining, but the best way to do it is to have someone sit in the car and work the shifter through all the gears. While they're doing that, spray everything you see moving and you'll end up with a short, firm shift that's MUCH more fluid moving through the gears, rather than fighting with each one like I was before. |
#28 |
I did the same. I do believe however that the changed angle of the shifter cable add some friction between the ssk pin and the bushing... The pin should rotate freely inside the bushing... the lubricant should help on this task. The feeling is 100% better and I would recomend this to al the people using the ssk. When I first install it I just thought that was the way it was... and it didn't felt bad... just a little tough... In my case the toughnes started after I installed the cable metal bushings |
#29 |
I agree... I thought the toughness/tightness was the way it was supposed to feel after the SSK. The WD40 made a huge difference.
#30 |
![]() ![]() Drives: 2008 Yaris S LB - MM Join Date: Aug 2009
I just purchased a Piggies a few minutes ago. I can't wait to see the results once I get it installed. Mind you, I've only been driving a manual for exactly two weeks, but by now I am good enough to notice a difference. :)
Can anyone tell me who's selling an NST 10% underdrive pulley for the cheapest price (including shipping)? Thanks in advance. |
#31 |
Slowy getting there
You can get the from Cali_Yaris" aka Garm aka Yaris God @ www.microimageonline.com
#32 |
just a warning, WD-40 eats at plastics, now i dont know what exactly is plastic or close enough to it that wd-40 would eat it, but i dont want to spray anything without knowing for sure.
#33 |
![]() ![]() ![]() Drives: '09 Yaris LB Join Date: Dec 2008
Yea. To further the wd40 concerns.
Wd40 is a degreaser. In my experience as a bike mechanic, folks will spray this stuff on moving parts and are generally releived at the results. I'm not saying it doesn't work (although it may be short lived) but an actual lubricant may be better and less harmful to rubber/plastic bits. Just a thought. |
#34 |
Will vegetable oil work? I suppose so.
| DIY: Make Your Own Short Shifter | 33OH | Cosmetic Modifications (Exterior/Interior) | 7 | 02-24-2009 01:06 PM |
| twm short shifter installed! | dngz | Performance Modifications | 115 | 08-02-2007 01:11 PM |
| TWM Short Shifter Boxing Week Blowout! | TWM Performance | Sponsors Classifieds Area | 2 | 01-08-2007 04:01 PM |
| November: Big Yaris Short Shifter Sale! | TWM Performance | Sponsors Classifieds Area | 14 | 12-12-2006 10:50 AM |
| TWM Yaris Short Shifter Sale! | TWM Performance | Sponsors Classifieds Area | 9 | 08-28-2006 03:37 PM |
