| View Poll Results: Would you buy one? | |||
| No |
5 | 5.10% |
| Yes (for $75) |
46 | 46.94% |
| Yes (but it would have to be less than $75) |
7 | 7.14% |
| Yes (but I still want it to also display the time) |
40 | 40.82% |
| Voters: 98. You may not vote on this poll | |||
Yes. It will use the same push button to change modes and set the clock. Programming for the one button user interface has been one of the most difficult aspects of this, but I wanted to avoid making people drill holes for extra switches.
![]() Drives: Yaris 2008 Sedan Join Date: Jan 2010
I am interested in how you'd incorporate it into the sedan! I'll buy.
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
Yes I agree with you, if you can add it I think it would be a good option. Also you mentioned you could remove the speed limiter, again some people might be interested in that also.
![]() Drives: 07 blazing blue hatch Join Date: Jan 2010
Hi all,
New to the forum here. CTScott - this one cool project you are undertaking. It is great enough to make me join the forum! Count me in for one of these. Thanks for your great work. |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
Looking good CTScott!
With these tap splices, will it be easy to put back the old unit, in case I would sell the car?
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
... and it probably wouldn't work on other cars unless you plan on getting another Yaris if you sold your current one.
![]() Drives: 2010 Hatchback Join Date: Jan 2010
After reading this thread it appears the YarGauge will not work on my 2010 3-dr manual, which has a tach on the left.
That's correct, since the clock is not a separate module, like on the tachless ones. I am trying to figure out where the YarGauge could be integrated to have the OEM look for tach equipped liftbacks and sedans.
![]() ![]() ![]() ![]() Drives: Black HB Join Date: Oct 2008
Oh that sucks. I was totally going to buy one but didn't know the new ones came with a tach lol.
About time, but I wanted all the other cool functions too lol. Can't have everything I guess? lol
#14 |
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
Still want me to take some pics of the inside of my cluster? I have one with a tach - just tell me what you need a pic of and I can do it tonight.
#15 | |
I obviously could mount it in a small enclosure, that you can put anywhere (like the scangauge), but that diminishes its value versus products like scangauge. |
#16 | |
One question though: since we can't replace the clock module, is hooking it up going to be more difficult? IE: are more spliced required? |
#17 | |
Ground, constant power, switched power, and possibly dimmer. To install the proto on my 09 w/out tach, I only had to tap one wire (outside temp sensor), as I realized that the two can bus connections could be made to two test points on the back of the cluster. |
#18 | |
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
For example when people get in my car I proudly tell them that some crazy CT electrical engineer fabricated up a switch for my airbags. This is a great project and you shouldn't fear the scangauge because yours is going to be way better! Also, as an owner of a tach, I would like to see a version of it fit under my single DIMM head unit or as an AC vent replacement, both are great ideas. |
| in dash clock as tach? | Cosmonaut | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 07-12-2010 11:27 AM |
| digital tach, 52mm, preferably blue leds | severous01 | Cosmetic Modifications (Exterior/Interior) | 5 | 05-15-2009 10:58 AM |
| Digital Tach | nqd | Performance Modifications | 4 | 05-17-2007 12:04 PM |
