Old 09-08-2009, 03:12 AM   #1
texkid
The one with cheese on it
Drives: '10 Corolla S
Reaching 30,000 miles and the mechanic says the shoes and pads still look new. Only had to turn the front rotors at about 20,000 miles (roughly).
DIY: A/C Insulation
texkid is offline   Reply With Quote
Old 09-08-2009, 12:29 PM   #2
supmet
Drives: 2007 4 Door Yaris
How can the pads look like new if you already had to turn your front rotors?
Old 09-08-2009, 12:36 PM   #3
o89canucks
Mechanic from hell
o89canucks's Avatar
Send a message via Yahoo to o89canucks
The rotors can still get warped or glaze over without wearing much of the actual pad surface off.
2007 Black Sand Toyota Yaris Sedan AT
2006 Sonic Blue Volvo S60R AWD 6MT
o89canucks is offline   Reply With Quote
Old 09-08-2009, 01:12 PM   #4
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
It's pretty much unheard of for disk brake rotors to actually warp. They get irregular patches of brake pad material deposited on the surface when used hard, especially if left with the pads in stationary contact with them while hot (i.e., the car's stopped for a bit after making a hard panic stop), and that makes the car shudder and pedal pulsate. Turning the rotor takes that off and gives a clean new surface, but they may also clean up with gentle normal use for a while, or with vigorous cleaning.
Old 09-08-2009, 02:14 PM   #5
1stToyota
1stToyota's Avatar
I don't know. I've turned lots of rotors over the years and what I see is runout and warpage (as in making two or three passes and still only removing metal at...let's say 12 o'clock, outboard, and 7 o'clock, inboard, for example). Now's the best time to see warped rotors because they're made so thin to save weight that they're usually below machine minimum (not discard thickness) after using up 1 set of pads.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 09-08-2009, 02:53 PM   #6
o89canucks
Mechanic from hell
o89canucks's Avatar
Who told you that pile of garbage???
I have resurfaced a lot of rotors and you can definetly tell that a rotor has lateral runout when it is on the brake lathe. Take a hot rotor and drive through a puddle or snow and it is like taking a hot pan off the stove and pouring cold water into it from the sink. I have even seen the lateral runout be so bad (most common in Mitsubishi's) that the steering wheel will have a shimmy while the brakes aren't applied.
The clamping force of the pads against the rotor is so stong that even if your theory of "brake pad deposits" had any truth to it, the "brake pad deposits" would be removed the very next time that you braked.
I guess flywheels never get hotspots in them either or warp out and never need to be resurfaced either if this theory were true?
Old 09-08-2009, 05:06 PM   #7
Yaris Hilton
Smile
There are lots of other experienced mechanics who'd disagree with you on those points. I'll cite this reference:
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Old 09-08-2009, 05:13 PM   #8
1stToyota
1stToyota's Avatar
While pads do a fine job at removing rust they're not cutting bits for removing large amounts of iron, and holding steady pressure on a stomped pedal isn't the same as locking bits down in place on a lathe.
2008 Scion xD
Old 09-08-2009, 05:54 PM   #9
o89canucks
Mechanic from hell
o89canucks's Avatar
If I remember correctly, this post was about longevity of the front brake pads, not on if rotors warp or not.
and for the stoptech garbage, you don't believe all the crap you read on the internet, do you?
Old 09-10-2009, 03:08 AM   #10
WolfWings
WolfWings's Avatar
Drives: Silver 2007 3Dr - Gryph
Oh gods, this, right here, and frying alternators so often most folks with this car I know keep a spare one in the trunk and can change it in under five minutes, are the two things I don't miss at all about owning a DSM Eclipse.
Being able to run up to triples in 3rd gear though was always nice, since mine was the FWD model. Muscle cars hate it when you just cruise past them frantically mashing their shifter up and down while you keep both hands on the steering wheel, thinking an automatic just beat them. Nah, just good gearing.
As for the brake pads: 45k here, they still look almost new, rotors and shoes too. I engine-brake as much as I can though, I'll admit, to the point friends always insist I ride at the rear of convoy's because I never give any visual warning of my speed to those behind me.
WolfWings is offline   Reply With Quote
Old 08-12-2011, 06:30 PM   #11
bronsin
bronsin's Avatar
Lets put it this way:
MY rotors never warp.
Nor the flywheel.
Old 08-12-2011, 08:01 PM   #12
"G"
Drives: 2007 Yaris Hatch
I have seen them warp from over tightening lug nuts or incorrectly torquing them.
"G" is offline   Reply With Quote
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
Front spoiler koolerking Australia 3 07-20-2009 08:10 PM
Front bra for S model Sedan? N9QGS DIY / Maintenance / Service 2 06-27-2009 08:51 PM
