Mechanic from hell
The rotors can still get warped or glaze over without wearing much of the actual pad surface off.
2007 Black Sand Toyota Yaris Sedan AT 2006 Sonic Blue Volvo S60R AWD 6MT |
Half a Bubble Off Plumb
It's pretty much unheard of for disk brake rotors to actually warp. They get irregular patches of brake pad material deposited on the surface when used hard, especially if left with the pads in stationary contact with them while hot (i.e., the car's stopped for a bit after making a hard panic stop), and that makes the car shudder and pedal pulsate. Turning the rotor takes that off and gives a clean new surface, but they may also clean up with gentle normal use for a while, or with vigorous cleaning.
#3 | |
#4 | |
Mechanic from hell
I have resurfaced a lot of rotors and you can definetly tell that a rotor has lateral runout when it is on the brake lathe. Take a hot rotor and drive through a puddle or snow and it is like taking a hot pan off the stove and pouring cold water into it from the sink. I have even seen the lateral runout be so bad (most common in Mitsubishi's) that the steering wheel will have a shimmy while the brakes aren't applied. The clamping force of the pads against the rotor is so stong that even if your theory of "brake pad deposits" had any truth to it, the "brake pad deposits" would be removed the very next time that you braked. I guess flywheels never get hotspots in them either or warp out and never need to be resurfaced either if this theory were true?
There are lots of other experienced mechanics who'd disagree with you on those points. I'll cite this reference:
http://www.stoptech.com/tech_info/wp...rakedisk.shtml |
While pads do a fine job at removing rust they're not cutting bits for removing large amounts of iron, and holding steady pressure on a stomped pedal isn't the same as locking bits down in place on a lathe.
#7 | |
Mechanic from hell
and for the stoptech garbage, you don't believe all the crap you read on the internet, do you?
#8 | |
Apexing Egg!!
i got 60k out of my oem pads with a half dozen track days and lots of autoxes.
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
#9 | |
Mechanic from hell
#10 | |
![]() ![]() ![]() Drives: Silver 2007 3Dr - Gryph Join Date: Jul 2007
Being able to run up to triples in 3rd gear though was always nice, since mine was the FWD model. Muscle cars hate it when you just cruise past them frantically mashing their shifter up and down while you keep both hands on the steering wheel, thinking an automatic just beat them. Nah, just good gearing. As for the brake pads: 45k here, they still look almost new, rotors and shoes too. I engine-brake as much as I can though, I'll admit, to the point friends always insist I ride at the rear of convoy's because I never give any visual warning of my speed to those behind me.
#11 | |
Lets put it this way: MY rotors never warp. Nor the flywheel. |
![]() ![]() ![]() Drives: 2007 Yaris Hatch Join Date: Feb 2007
I have seen them warp from over tightening lug nuts or incorrectly torquing them.
I just had my serpentine belt replaced for the first time last week at 207,135 miles and I had them check my brakes as well. My brakes are wearing evenly and are only 20 percent worn. I think the rate of wear is partially due to driving habits and partially due to the terrain where you live. I do a lot of engine braking as well as coasting up to traffic signals when it is safe to do so. I also usually drive at the speed limit or up to 5 MPH under the speed limit. I think that those of us who live (or normally drive) in flat or RELATIVELY flat areas (I live in Southern Montgomery County, just north of Houston and you in St. Louis) also get more miles from our brakes. I previously lived (and most of my extended family still lives) in the San Francisco Bay Area and generally people wear their brakes out MUCH faster there.
| lowering spring specs for Yaris | botchilah | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 03-22-2017 08:47 AM |
| Get your post counts here! *read 1st post for rules* | Astroman | Off-topic / Other Cars / Everything else Discussions | 3414 | 11-04-2012 09:03 AM |
| Which front bar do you prefer? Strut or Sway? | TitaniumBarbell | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 10-16-2009 11:52 AM |
| Front spoiler | koolerking | Australia | 3 | 07-20-2009 08:10 PM |
| Front bra for S model Sedan? | N9QGS | DIY / Maintenance / Service | 2 | 06-27-2009 08:51 PM |
