Old 09-14-2009, 09:44 AM   #1
flutie98
Drives: Toyota Yaris
For the pin 40 connection, the ideal thing would be to use one of the actual waterproof pins for that connector. You can actually purchase the terminal, with a wire pre-crimped to it from Toyota:
82998-24250 is a single wire with the terminal and waterproof plug for connecting to the ECM.
Otherwise, I would at the very least put a dab of silicone where the wire enters the connector to keep moisture out.
I just ordered this part and attempted to install it. I think it might be the wrong part #, its just a little big and will not fully seat in the connector. And let me tell you I tried to force it in there.
flutie98 is offline   Reply With Quote
Old 09-14-2009, 10:24 AM   #2
Can you snap some pictures? There are three pins for the A21 connector. 82998-24250 is the smallest width of the three. The two others are for the wider width pins.
Also, the pin will only fully insert in one position. If it is flipped over, it will go in most of the way, but will not seat.
Old 09-14-2009, 10:54 AM   #3
flutie98
Ill snap some pics when i get home from work. I tried all 4 orientations and the one that seats the most still is not fully in.
Old 09-14-2009, 03:17 PM   #4
Soylentglass
Drives: 2009 Yaris Sedan
I posted yesterday the results of my install on my 09 manual sedan and at first I ran into the same problem with the repair terminal not fitting. I ripped the waterproofing sleeve trying to jam it in with fine needle nose pliers.
My post is at the end of http://www.yarisworld.com/forums/sho...=16188&page=30
On connector A21 there is a locking mechanism that you must push to one side to allow the terminal to slide in place and yes it would only go in one way, which happened to be the 4th position I tried. You then push back the white plastic slide piece and it will lock the terminal in place.
Soylentglass is offline   Reply With Quote
Old 09-14-2009, 09:17 PM   #5
flutie98
hmm any pics as to where that locking slider is?
Old 09-14-2009, 10:43 PM   #6
It's the white thing at one end of the connector:
Lock latched:
Lock released:
Pop it with a small screwdriver from the side:
Old 09-15-2009, 08:52 AM   #7
flutie98
well darn, I feel like an idiot now. Thanks CTScott
Old 09-15-2009, 06:46 PM   #8
julienrl
Drives: 2007 yaris
where do you buy this wire using the part number?
julienrl is offline   Reply With Quote
Old 09-15-2009, 09:17 PM   #9
You can order it through your local dealer or from TRDsparks.com
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
